pcelenta
Joined: 16 Feb 2007 Posts: 546 Location: long island,ny
Posted: Sun May 05, 2013 8:55 am Post subject: water pump with plastic impeller |
so I picked up a water pump for the 80 S1 from autozone...opened the box and it looked like the usual GMB pump casting wise...then I flipped it over to find a plastic impeller. quite odd but I suppose new technology. I am a little sketchy on the idea of a plastic impeller. what are the thoughts out there? return it and get a GMB with metal impeller or give this one a try.
Paul |
Posted: Sun May 05, 2013 10:10 am Post subject: |
Beemer pumps have been constructed this way for years. _________________ Toofah King Bad
Fifty50Plus
Joined: 28 Feb 2008 Posts: 1423 Location: Washington DC area
Posted: Sun May 05, 2013 11:18 am Post subject: |
I've had a few plastic impellers slip on the shaft and the engine runs hot. Fix was to pin the impeller.  _________________ 1979 924 NA race car H-Prod SCCA
1982 924 NA race car - Sold
1981 924 Turbo sold
1982 924 Turbo sold
mikebola
Joined: 07 Sep 2009 Posts: 361 Location: Parkside, PA
Posted: Mon May 06, 2013 9:09 am Post subject: |
working for a company that uses plastic turbines and impellers on steel axles that are made to spin up to 30k rpm, I have to agree that it's only a matter of time before it slips on the axle, even if it's knurled or flattened. _________________ proud owner of a 1979 924 Sebring Edition with a 931 trans that looks horrible but somehow runs... |
Posted: Mon May 06, 2013 11:21 am Post subject: |
Having replaced a couple of those BMW plastic impeller pumps with the much more desirable metal impeller pumps, I can tell you the BMW crowd does not like the plastic pumps, myself included.
I've never seen a plastic impeller 924 (early) pump. |
pcelenta
Posted: Tue May 07, 2013 4:37 am Post subject: |
| autozone must have a new supplier because the last one I picked up from them had a metal impeller. I have to look to see if it is pinned...if not I may just bring it back. |
txjake
Joined: 17 Feb 2007 Posts: 395 Location: Oklahoma City OK
Posted: Tue May 07, 2013 5:59 am Post subject: |
never met a plastic impeller that I liked _________________ 1978 924, aka The Red Rocker |
Posted: Tue May 07, 2013 7:36 am Post subject: |
The ones I provide are GEBA brand and are all metal.
Water pump by itself is $63 + shipping. _________________ erstwhile owner of just about every 924 variant ever made |
pcelenta
Posted: Thu May 09, 2013 1:43 am Post subject: |
thanks dan, I'll be ordering from you shortly.
regards,
Paul |
