I'm in a bit of a pickle any ideas?
nickthompson
PostPosted: Fri May 03, 2013 7:10 am    Post subject: I'm in a bit of a pickle any ideas? Reply with quote
One of the studs on the exhaust manifold flang on the output side stripped almost clean. When I pulled the mani off I thought they looked kind of iffy now I'm wondering if there are options.
joemac
PostPosted: Fri May 03, 2013 7:18 am    Post subject: Reply with quote
Duck tape?
If the manifold is off, I can think of no option other than to replace the offending stud.
This is the job for Kroil.
If you don't know about Kroil, it's time...
Race car: my favourite palindrome.
Porsche: my favourite race car.
nickthompson
PostPosted: Fri May 03, 2013 7:21 am    Post subject: Reply with quote
joemac wrote:
If the manifold is off, I can think of no option other than to replace the offending stud....
The manifold is not off. I'm not sure I could get the stud off if it was.
leadfoot
PostPosted: Sat May 04, 2013 10:57 am    Post subject: Reply with quote
Depending on which stud you may be able to get at it with a right angle drill attachment and then use an extractor or tig weld the nut on and remove with a spanner.
With many a scraped knuckle get the manifold off in situ and use a stud extractor or pull the head...
Id be doing the tig option if i had the room myself and loosening the engine mounts if i needed to get some extra room.
Stu
1981 ROW 924 Turbo -
carbon fiber GT mish mash
LS1 conversion in progress...
Kens_74_911s
PostPosted: Sun May 05, 2013 4:47 am    Post subject: stud Reply with quote
Pretty small stud to use an extractor on. If there is little to none sticking out it’s somewhat difficult to get enough weld there but possible since it will thermally wake up the connection.
In my early days of old Air cooled VWs I have had several studs break off. we would normally do this :
*grind it flat if it didn’t shear off flat ( so drill won't walk)..
*center punch on center.
*center drill.
*pilot drill smaller than tap drill, drill with tap drill.
*attempt to re-tap picking up existing threads.
If tapping is unsuccessful, there are stepped studs available as a worse case. Go to M8x1.25 with a stepped stud, Heli-coil is another option. Either way need to get drilling. You may need to use shortened drills with motor off its mounts to angle it for clearance or remove the head.
Ken - ebay: wandrey1 , *0 , *00 , *01
74 911s widebody
96 BMW 750iL
99 BMW 328i
81 VW MK1-1.8 GTI, 5 spd Pickup
02 Explorer (wife's)
92 BMW 735iL Parting
84,85,86x3,87,944. 82-924,88-924s parted
68, 70, 72, 73, 911~ 70,73 914 past Pcars
PostPosted: Mon May 06, 2013 12:57 am    Post subject: Reply with quote
Replace ALL manifold and turbo studs at every opportunity if the manifold is off. Is it off? I couldn't remove it with engine insitu.
nickthompson
PostPosted: Mon May 06, 2013 1:33 am    Post subject: Reply with quote
It's the studs on the flang side not the studs in the head. I used socket head bolts from Fastenal in the head.
txjake
PostPosted: Mon May 06, 2013 3:20 am    Post subject: Reply with quote
I don't mess with manifold studs anymore. I justae them to a machine shop.
1978 924, aka The Red Rocker
nickthompson
PostPosted: Mon May 06, 2013 3:27 am    Post subject: Reply with quote
I've got a couple of ideas when I get back from Alabama I'll see which one works. Can't wait to drive it.
PostPosted: Mon May 06, 2013 6:44 am    Post subject: Reply with quote
Mine snapped off. Let them and pull the manifold. Grind them flat and center punch them and start drilling them out to the proper size to tap them for new studs.
Reassemble with high temp anti-seize and new gaskets.
Or if like me and you find your exhaust manifold has cracked near the head, buy a header and solve the problem
nickthompson
PostPosted: Mon May 06, 2013 9:15 am    Post subject: Reply with quote
If I had the money I would have bought a header too. I emptied my auto fund and it's going to be empty for a few months now.
