What oil should I use?
xanderdeg
PostPosted: Tue Apr 23, 2013 10:53 am    Post subject: What oil should I use? Reply with quote
Doing my spring oil change within the next couple of days, just wondering what viscosity to use for the spring/summer months? I'm currently running 10w30 non synthetic oil.
PostPosted: Tue Apr 23, 2013 1:24 pm    Post subject: Reply with quote
PostPosted: Tue Apr 23, 2013 1:43 pm    Post subject: Reply with quote
I use 20-50 dino juice year round.
78 924 NA
5-lug
xanderdeg
PostPosted: Tue Apr 23, 2013 1:50 pm    Post subject: Reply with quote
Synthetic? I hate to bring it up, but would regular oil with the same viscosity be pretty much the same?
PostPosted: Tue Apr 23, 2013 2:13 pm    Post subject: Reply with quote
Dino juice means not synthetic.
It depends on your motor. Mine uses oil, so synthetic would be way too expensive. It's also old and tired, so thicker oil makes sense.
Synthetics are a no-brainer in a turbo motor. Synthetic and conventional are NOT the same, but conventional is good enough for many applications.
78 924 NA
5-lug
txjake
PostPosted: Tue Apr 23, 2013 2:45 pm    Post subject: Reply with quote
Brad Penn is very good.
1978 924, aka The Red Rocker
PostPosted: Tue Apr 23, 2013 3:10 pm    Post subject: Reply with quote
No. If you want to run dino I would not go 5w40.
CorsePerVita
PostPosted: Tue Apr 23, 2013 11:04 pm    Post subject: Reply with quote
20-50 brad penn is what i use on my cars.
- 1980 Porsche 931 (Daily)
- 1987 Lamborghini Jalpa
- 1999 Ducati 900SS
PostPosted: Wed Apr 24, 2013 12:28 am    Post subject: Reply with quote
You wanna see something funny check out the oil threads on Pelican. . .people get seriously pissed off.
MikesCoupeGT
PostPosted: Wed Apr 24, 2013 12:49 am    Post subject: Reply with quote
I just put the Penn 20 - 50 in my car last weekend.
I would tend to stay away from the Synthetic unless it has been used for a while before. Or if you have just done a motor rebuild and are starting from scratch oil wise. I would probably use a high mileage oil as well.
just my thoughts. I went with Penn as my car will be tracked a bit this summer.
Cheers;
MikesCoupeGT
'76 924
'83 944
''19 Elantra GT N-Line
View user's profile Send private message Yahoo Messenger MSN Messenger
joemac
PostPosted: Wed Apr 24, 2013 8:50 am    Post subject: Reply with quote
Yup. No more oil light/buzzer troubles (several VW's).
Race car: my favourite palindrome.
Porsche: my favourite race car.
xanderdeg
PostPosted: Wed May 01, 2013 1:30 pm    Post subject: Reply with quote
Put 20 50 in yesterday and IT'S TOO THICK!
Idles at just above 2bar when warm (not that bad)
Cruising on the highway at 3k rpm reads 5.8bar (pretty damn high)
Above 3k rpm it goes up to about 6.3bar and then stops ascending.
Thinking I'll go out and buy some 10 30 since that seemed to work well before. Maybe some 10 40.
Anybody want to buy some barely used 20w 50 Castrol dino juice?
Duncan
PostPosted: Wed May 01, 2013 5:56 pm    Post subject: Reply with quote
I am not an expert, but would be really happy with those numbers.
I am running the same weight oil and get the same numbers.
1983 NA Alpineweiss since 2001
Peugeot 205 Generation
PostPosted: Thu May 02, 2013 12:20 am    Post subject: Reply with quote
Those pressures are good per FSM. Plus, they will go down after a few heat cycles.
xanderdeg
PostPosted: Thu May 02, 2013 3:41 pm    Post subject: Reply with quote
Hmm, they seemed a little high to me. But I probably know less than you guys do
10 30 gave me very different pressures that seemed a little more "comfortable" (4bar at 3krpm on the highway. Idling at 1bar.)
I'll see how it goes. Thanks guys!
