Did someone ever mount a turbo on a plain 2.0 engine?
Goto page Previous  1, 2, 3  Next
dial67
PostPosted: Tue Apr 09, 2013 11:36 am    Post subject: Second try Reply with quote
dial67
PostPosted: Tue Apr 09, 2013 11:40 am    Post subject: Third try Reply with quote
Karpaazio
PostPosted: Wed Apr 10, 2013 12:08 am    Post subject: Reply with quote
Dial what turbo are you using? How much boost? Hows your afr?
Porsche 924 1978 Cabrió:
http://www.garaget.org/?car=219790
Porsche 924 widebody (next up?)
Toyota Crown LS110 1983:
http://www.garaget.org/?car=260537
Audi a6 2.7tt quattro 2000 daily driver
dial67
PostPosted: Wed Apr 10, 2013 2:57 am    Post subject: Reply with quote
I am not sure of the exact turbo model. It is a T25 that I got for $20.00 used. It runs about 6-7 lbs thru the FMIC. I have a PLX M300 that I plan to check the AFR. Right now I am working on the Turbo Fueller for ignition control and fuel enrichment. Once I get the TF unit running I will upgrade the turbo to a GT2860RS. I will post more pics shortly.
dial67
PostPosted: Wed Apr 10, 2013 10:45 am    Post subject: Injector mount Reply with quote
Here is a pic that shows the two injectors mounted. This was a primary rail from a 1993 Mazda RX7.[img]http://imageshack.us/a/img407/1127/sdc10093z.jpg
[/img]
dial67
PostPosted: Wed Apr 10, 2013 10:55 am    Post subject: Reply with quote
dial67
PostPosted: Wed Apr 10, 2013 11:00 am    Post subject: Turbo and downpipe Reply with quote
This pic shows the adapter plate for the turbo and downpipe.
dial67
PostPosted: Wed Apr 24, 2013 11:12 am    Post subject: Test run Reply with quote
I got the PLX hooked up today and found that the engine was running to lean. The 3mm screw to adjust the AFR is gone. I do not think that there has been one on the fuel dizzy as long as I have had the car. I removed all the shims from the pressure regulating valve and was able to get a fair AFR. I have not turned up the boost passed 7lbs yet. Between 5-7lbs I am seeing 12:1 to 10.5:1 on the CIS only. I have no need to add fuel from the extra injectors at this time. The GT2860RS is the next step along with a knock sensor.
Karpaazio
PostPosted: Sat Apr 27, 2013 6:15 am    Post subject: Reply with quote
I'm running 0,6 bar of boost and I just made the wur adjustable and raised the control pressure little bit higher. AFR was showing 13.5 at full throttle.
Here is a small video: http://youtu.be/CAzfeL09zMI
flosho
PostPosted: Sat Apr 27, 2013 6:50 am    Post subject: Reply with quote
13.5 is generally pretty lean for a turbo car, unless you raised the control pressure after the video? I would want to see the afr closer to 11.8-12.2 at wot.
[This Space For Rent]
Karpaazio
PostPosted: Sat Apr 27, 2013 7:02 am    Post subject: Reply with quote
Going to run it more rich flosho, as the video shows it was the first test run and it ran like that. Maybe tomorrow if I got time I will tune it closer to 12
Arvidw
PostPosted: Sat Apr 27, 2013 7:39 am    Post subject: Reply with quote
That sounds promising, very nice uncomplicated build
Porsche 924 2.0 Kompressor 136.1wHp @ 5650rpm / 201.9wNm @ 3900rpm (dyno @ dp-engineering.nl)
PostPosted: Sat Apr 27, 2013 6:26 pm    Post subject: Reply with quote
it actually looks nicer in the videos than in the pictures
Karpaazio
PostPosted: Sat Apr 27, 2013 7:02 pm    Post subject: Reply with quote
I just adjusted the mixture, ran on 3rd gear wot with 12,4 AFR. I have to get new water temp meter because the car got overheated when I got home and the meter was in the midle of cold and red... :/
Raceboy
PostPosted: Sun Apr 28, 2013 6:41 am    Post subject: Reply with quote
It's not the meter, it's the head gasket.
'83 924 2.6 16v Turbo, 470hp
'67 911 2.4S hotrod
'90 944 S2 Cabriolet
'78 924 Carrera GT replica
'84 928 S, sold
'91 944 S2, sold
'82 924S/931 "Gulf", sold
'84 924, turbocharged, sold.
Page 2 of 3
