wheel rubs
Goto page Previous  1, 2
PostPosted: Tue Jan 15, 2013 7:02 pm    Post subject: Reply with quote
Early offset 944 wheels (i.e. those <50mm offset, most in the 23mm range) will not work on the 924 setup, as they will stick out too far with or without spacers.
Don't understand this statement.
It depends if you are trying to fit the wheels with monstrous tyres or not. Pretty sure Cedric and myself are running 7'' ET23 wheels on our cars. In fact I'll be going from the temporary 10mm rear spacer to the OEM 21mm spacer soon to fill the arch better.
Fitting non standard wheels and tyres is more than just bolting up and thinking, shit it doesn't work! Tyres, ride height, cambers etc. can all be adjusted to work.
In fact 8 and 9'' wheels will work on a narrow 924/931 as long as you work at it.
kcoyle
PostPosted: Wed Jan 16, 2013 12:51 am    Post subject: Reply with quote
Well, the suspension is already on there, so the simplest thing to do would try some negative camber ands see what happens. Also, you can get some 928 trashcans in 65mm offset i believe, bit then you may have issues on the inside rubbing.
I have 7x16 52mm offset trashcans on my 5lug 931 running 225's which was to me the best compromise of bigger wheels with no grief.
PostPosted: Wed Jan 16, 2013 1:03 am    Post subject: Reply with quote
When I tried putting the standard issue 23mm cookie cutters on my 81 NA, the front wheels stuck out too far, about an inch beyond the fenders.
What I learned from that exercise is that the ET23 wheels will work in the rears if you remove the stock spacers, but then they appear a bit too inset, so some thinner spacers would ideal. If you leave the stock spacers on in the rear, they will rub the inner fender lip, especially with stock alignment settings and dampers. They will not work in the front without massive adjustments to camber, which may be great for the track, but will burn thru tires more quickly than most might prefer for the street.
SlayerSST
PostPosted: Mon Apr 22, 2013 11:31 am    Post subject: Reply with quote
Fixed it:
before
after
Karpaazio
PostPosted: Tue Apr 23, 2013 2:40 am    Post subject: Reply with quote
I've got alu trailing arms and hubs from an 86' 944 and I've got 16x8" et11 wheels in the rear and 16x7 et 20 in front.
Here is how it looks
And I have just a mild stretch on the rear tires
Porsche 924 1978 Cabrió:
http://www.garaget.org/?car=219790
Porsche 924 widebody (next up?)
Toyota Crown LS110 1983:
http://www.garaget.org/?car=260537
Audi a6 2.7tt quattro 2000 daily driver
SlayerSST
PostPosted: Tue Apr 23, 2013 5:01 am    Post subject: Reply with quote
That looks very nice. I like the mirror finish on the rims.
vatoisimo
PostPosted: Tue Apr 23, 2013 10:44 am    Post subject: Reply with quote
I am running into this issue right now with 15" cookie cutters. the rears look pretty good, but the front stick out about an inch. Was going to try a low profile tire to see how that looked. I am thinking that I just need to spring for some turbo twists and set up the car like raceboys white one.
Page 2 of 2
