1982 924 na timing belt
awolak
PostPosted: Mon Apr 22, 2013 10:22 am    Post subject: 1982 924 na timing belt Reply with quote
I have just replaced the timing belt and left the cover off cause I suspected the belt was rubbing on it due to wear marks on the old belt. I centered the belt on the cam pulley when I replaced it and after running it for a bit the belt has traveled towards the front of the engine and now overhangs the cam pulley about 1/16 ". I centered it again and it does the same thing. Could it be the tensioner is worn and causing the belt to travel? What do you guys think? Thanks in advance.
SlayerSST
PostPosted: Mon Apr 22, 2013 10:52 am    Post subject: Reply with quote
Yeah it is the tension pulley. Get a new one and problem solved.
CorsePerVita
PostPosted: Tue Apr 23, 2013 4:07 am    Post subject: Reply with quote
The tensioner pulley greatly regulates how far the belt is forward/back. If the pulley itself doesn't have weird play, make sure the crank pulley isn't having issues too. It's unlikely, and very likely the tensioner pulley. But it's always good to check clearances on stuff "while you're down there"...
- 1980 Porsche 931 (Daily)
- 1987 Lamborghini Jalpa
- 1999 Ducati 900SS
PostPosted: Tue Apr 23, 2013 4:48 am    Post subject: Reply with quote
Also, and this is purely anecdotal (my one and only experience, worked for me), you might not have the belt tight enough.
awolak
PostPosted: Tue Apr 23, 2013 8:39 am    Post subject: Reply with quote
Thanks guys, I will start checking and post what I find.
awolak
PostPosted: Wed Jul 13, 2016 2:09 am    Post subject: Reply with quote
Well I just got around to changing the tensioner, haha. We moved to a farm and farm things took precedence.
I posted a few days ago about timing belt woes and was so zeroed in on why the car wouldn't start I forgot to mention that with the new tensioner the belt still does the same thing. It travels towards the front of the car and over hangs about 1/16 inch.
What clearances should I be looking at and what else if anything?
Thanks
1982 924 N/A
2011 Nissan Rogue Krom
2006 Range Rover Sport HSE
2002 BMW 330 CI
2000 Audi A6 Quattro
2000 Chevy Tahoe LS
