944 petrol filling problem
daniel
PostPosted: Sun Apr 21, 2013 1:33 pm    Post subject: 944 petrol filling problem Reply with quote
I have had a 944 S2 for about 5 years now, it has always been difficult to fill up. If you open the tap on the bowser by more than about one half, it clicks off. Lately this has become much worse. Does anyone have have any ideas about what causes this and how to fix it?
1989 944 Cabriolet
PostPosted: Sun Apr 21, 2013 2:37 pm    Post subject: Reply with quote
Tank vent is plugged or collapsed. Fuel rushes in and displaces the air, but if the air can't leave fast enough something's gotta give.
Unfortunately that means dropping the tank and replacing the hoses. Sucks but it's gotta be done to get it right.
daniel
PostPosted: Sun Apr 21, 2013 2:47 pm    Post subject: Reply with quote
That would explain why sometimes I smell fuel on the car, ill check it out.
1989 944 Cabriolet
944phan
PostPosted: Thu Apr 25, 2013 8:25 am    Post subject: 944 petrol filling problem Reply with quote
I had what sounds like the same problem on my 1978 924. I found that after putting the nozzle into the tank filler, if I tipped the it down, the problem went away.
944phan
PostPosted: Thu Apr 25, 2013 8:26 am    Post subject: 944 petrol filling problem Reply with quote
I had what sounds like the same problem on my 1978 924. I found that after putting the nozzle into the tank filler, if I tipped it down, the problem went away.
PostPosted: Thu Apr 25, 2013 9:15 am    Post subject: Reply with quote
Check the lines and valve under the filler tube cover in the rear hatch before going too crazy.
