dial67
Posted: Tue Apr 09, 2013 11:36 am Post subject: Second try |
dial67
Posted: Tue Apr 09, 2013 11:40 am Post subject: Third try |
Karpaazio
dial67
Posted: Wed Apr 10, 2013 2:57 am Post subject: |
| I am not sure of the exact turbo model. It is a T25 that I got for $20.00 used. It runs about 6-7 lbs thru the FMIC. I have a PLX M300 that I plan to check the AFR. Right now I am working on the Turbo Fueller for ignition control and fuel enrichment. Once I get the TF unit running I will upgrade the turbo to a GT2860RS. I will post more pics shortly. |
dial67
Posted: Wed Apr 10, 2013 10:45 am Post subject: Injector mount |
Here is a pic that shows the two injectors mounted. This was a primary rail from a 1993 Mazda RX7.[img]http://imageshack.us/a/img407/1127/sdc10093z.jpg
[/img] |
dial67
Posted: Wed Apr 10, 2013 10:55 am Post subject: |
dial67
Posted: Wed Apr 10, 2013 11:00 am Post subject: Turbo and downpipe |
This pic shows the adapter plate for the turbo and downpipe. |
dial67
Posted: Wed Apr 24, 2013 11:12 am Post subject: Test run |
| I got the PLX hooked up today and found that the engine was running to lean. The 3mm screw to adjust the AFR is gone. I do not think that there has been one on the fuel dizzy as long as I have had the car. I removed all the shims from the pressure regulating valve and was able to get a fair AFR. I have not turned up the boost passed 7lbs yet. Between 5-7lbs I am seeing 12:1 to 10.5:1 on the CIS only. I have no need to add fuel from the extra injectors at this time. The GT2860RS is the next step along with a knock sensor. |
Karpaazio
flosho
Posted: Sat Apr 27, 2013 6:50 am Post subject: |
13.5 is generally pretty lean for a turbo car, unless you raised the control pressure after the video? I would want to see the afr closer to 11.8-12.2 at wot. _________________ [This Space For Rent] |
Karpaazio
Posted: Sat Apr 27, 2013 7:02 am Post subject: |
Going to run it more rich flosho, as the video shows it was the first test run and it ran like that. Maybe tomorrow if I got time I will tune it closer to 12  _________________ Porsche 924 1978 Cabrió:
http://www.garaget.org/?car=219790
Porsche 924 widebody (next up?)
Toyota Crown LS110 1983:
http://www.garaget.org/?car=260537
Audi a6 2.7tt quattro 2000 daily driver |
Arvidw
Joined: 20 Sep 2009 Posts: 227 Location: The Nederlands (Europe)
Posted: Sat Apr 27, 2013 7:39 am Post subject: |
That sounds promising, very nice uncomplicated build  _________________ Porsche 924 2.0 Kompressor 136.1wHp @ 5650rpm / 201.9wNm @ 3900rpm (dyno @ dp-engineering.nl) |
Posted: Sat Apr 27, 2013 6:26 pm Post subject: |
it actually looks nicer in the videos than in the pictures  _________________ Supercharger and EFI kits
Karpaazio
Posted: Sat Apr 27, 2013 7:02 pm Post subject: |
I just adjusted the mixture, ran on 3rd gear wot with 12,4 AFR. I have to get new water temp meter because the car got overheated when I got home and the meter was in the midle of cold and red... :/ _________________ Porsche 924 1978 Cabrió:
Raceboy
Posted: Sun Apr 28, 2013 6:41 am Post subject: |
It's not the meter, it's the head gasket. _________________ '83 924 2.6 16v Turbo, 470hp
'67 911 2.4S hotrod
'90 944 S2 Cabriolet
'78 924 Carrera GT replica
'84 928 S, sold
'91 944 S2, sold
'82 924S/931 "Gulf", sold
'84 924, turbocharged, sold.
