Dimly Glowing ALT Light?
PostPosted: Tue Apr 09, 2013 9:57 am    Post subject: Dimly Glowing ALT Light? Reply with quote
You could wait until it actually starts causing a misfire, or you could take out a screwdriver and GO CHECK YOUR VOLTAGE REGULATOR NOW!
staticsan
PostPosted: Tue Apr 09, 2013 11:45 am    Post subject: Reply with quote
Ow.
Or you make the mistake I made. New battery with "calcium" plates. Didn't know this needed a higher voltage and probably higher current to charge. This also means driving at night the car isn't charging the battery.
Of course, the alternator light has been glowing for quite a while when I use the headlights...
Wade.
'82 British NA - Which I think I've been very lucky with!
PostPosted: Tue Apr 09, 2013 11:59 am    Post subject: Reply with quote
I found fitting a battery earth cable direct from the alternator frame to chassis worked wonders.
PostPosted: Tue Apr 09, 2013 4:48 pm    Post subject: Reply with quote
or replace the ground wire from the alternator...
staticsan
PostPosted: Sun Apr 14, 2013 9:40 pm    Post subject: Reply with quote
Hah. Auto-electrician didn't like me offering ideas from the 'net.
Not sure what was really wrong with my alternator. So they pulled it apart and cleaned it, put a new regulator in it and then they ran a new charging line right to the battery. So I guess a new ground cable was probably not so far off the mark!
Starts a lot better now. Accelerates slightly better, too.
Wade.
