crow.magnum
Joined: 13 Oct 2007 Posts: 50 Location: SOMERSET ENGLAND
Posted: Tue Feb 19, 2013 4:58 am Post subject: |
ii dont think it smelt of anything apart from hot car. its a very tight space ot see down there as well will try another look tomo .
would the battery problem be the car overcharging it if so what would cause that?? |
kcoyle
Posted: Tue Feb 19, 2013 5:57 am Post subject: |
| Quote: | | would the battery problem be the car overcharging it if so what would cause that?? |
Yup, could be. The voltage regulator might be shot. Check the voltage at the battery terminals with the car running and make sure it's not through the roof. You should get around 13.5 volts. _________________ 1982 931- Stock with MBC at 8psi
Posted: Tue Feb 19, 2013 6:31 am Post subject: |
You said turbo just makes noise but no power. Check A/F ratio and the wur. Also check for proper timing as this is an s1 _________________ Supercharger and EFI kits
crow.magnum
Posted: Tue Feb 19, 2013 8:27 pm Post subject: |
Hi morghen hows you, must catch up on you project soon its been a while since ive been on forums .
The timing should be fine. I put a new mot on the car last july then I drive it around for a bit that day covered 50miles or so and it ran fine. I have not driven it since untill the other day. But I did start it in the garage every month .
And the problems have started . |
Posted: Tue Feb 19, 2013 8:40 pm Post subject: |
Glad you're back. good luck with the trouble shooting.
Any chance we get some pics of this car? _________________ Supercharger and EFI kits
crow.magnum
Posted: Tue Feb 19, 2013 9:03 pm Post subject: |
Yep sort some out later , thats if I havent took a sledge hamner to it in anger  |
Nein37
Joined: 29 Dec 2009 Posts: 513 Location: New London, CT
Posted: Tue Feb 19, 2013 11:31 pm Post subject: |
Considering it hasn't been driven in a good while I'd put my money on a fuel system issue. You need to get a CIS pressure tester and check pressures then you can go from there. _________________ 1981 931 CGT replica, OEM CGT intercooler, .8 BAR WG spring, GTS Headlights, Innovative Wide band A/F, A/C delete, 16" Fuchs, Weltmeister 200lb lowering springs, Bilstein HDs front, Koni Sport rears. |
crow.magnum
Posted: Wed Feb 20, 2013 3:45 am Post subject: |
ok this is what we are trying to sort out
[/URL]
[/img]
[/URL]
[/URL]
[/URL]
[/URL][/URL]
going to have a go tomo |
Posted: Wed Feb 20, 2013 4:56 am Post subject: |
those wheels again huh?
car look good, but a bit..."tuned"
i dont like the dials or door sills but thats an easy fix. _________________ Supercharger and EFI kits
crow.magnum
Posted: Thu Feb 21, 2013 3:10 am Post subject: |
| Hopefully one step forward alternator over charging battery so now that's In the battery shop being fixed. |
crow.magnum
Posted: Sat Feb 23, 2013 9:21 pm Post subject: |
alternator fixed and on the car.
Next problem drive car half a mile no boost from turbo and steam/smoke coming from the turbo area .
from start up cold car idles 1200 rpm after half mile run car idles a 2000 rpm.  |
Posted: Sun Feb 24, 2013 5:44 am Post subject: |
Wha, i like those rims. It looks like a shark. _________________ 1979 porsche 924 Na
Have u ever driven a turbo. |
crow.magnum
Posted: Tue Mar 12, 2013 4:41 am Post subject: |
Still no joy . Ive replaced all the small breather pipes and checked the rest. Turbo still fails to work. And now the oil lights come on may not be connected.
Any ideas ? |
Posted: Tue Mar 12, 2013 5:25 am Post subject: |
When revving whilst car is stationary do you get the turbo bypass valve 'clack' when abruptly coming off the throttle?
Is there oil leaks from the turbo?
Do you feel there is no boost at all?
Is there still steam/smoke?
You still got my number? _________________ 1980 931 - forged pistons, Piper cam, K27/26 3257 6.10 hybrid turbo, 951 FMIC, custom intake, Mittelmotor dizzy & cam pulley, H&S exhaust, GAZ Gold, Fuch'ed, Quaife
crow.magnum
Posted: Sun Mar 17, 2013 5:12 am Post subject: |
hi steve still got your number. will ring you soon.
engine idles between 1100 rpm to 2000 rpm only moving when reved
not sure about clack
turbo is a bit oily i do need to take the engine tray off and investigate from under the car .
not even driving the car but idleing and slight reving in the garage steam / smoke starts coming up from the turbo exhaust area . could the turbo be sezied up.
have i got 1 problem or a whole load of them ?? |
