Which hotside for 951 turbo conversion
Dutch924-racer
PostPosted: Wed Nov 28, 2012 11:45 pm    Post subject: Which hotside for 951 turbo conversion Reply with quote
Which hotside do I need for a 951 turbo conversion. Series 1 or 2 and what shoul the partnumber be stamped in the hotside, just to be sure.
937 trackday car
Series 2 engine
951S turbo and intercooler
Fast road camshaft
WEASEL149
PostPosted: Thu Nov 29, 2012 3:21 am    Post subject: Re: Which hotside for 951 turbo conversion Reply with quote
You need the larger nozzle area Series 1 Turbine housing.
S1 6.10 turbine housing part number is 5326 100 6328
Also be sure to get the later 951 Turbo fitted to the 250hp version, the one with the #8 Turbine housing, then swap the #8 for the above-mentioned #6.
1979 UK 932
Raceboy
PostPosted: Thu Nov 29, 2012 5:51 pm    Post subject: Reply with quote
And then you can sell the #8 hotside to me
'83 924 2.6 16v Turbo, 470hp
'67 911 2.4S hotrod
'90 944 S2 Cabriolet
'78 924 Carrera GT replica
'84 928 S, sold
'91 944 S2, sold
'82 924S/931 "Gulf", sold
'84 924, turbocharged, sold.
peterld
PostPosted: Fri Nov 30, 2012 3:56 pm    Post subject: Reply with quote
So...if you guys are also fooling around with 951 turbos, can you please enlighten me on what the threaded ports on the intermediate are for: one on the left hand side and two on the right.
I believe two are for oil....but which two...and which is input/output, and what is the third port for?
All appear to be the same size, around 16mm with 1.5mm pitch?
80/81 932/8 ROW
Dutch924-racer
PostPosted: Sat Dec 01, 2012 5:43 am    Post subject: Reply with quote
The two 944 hotsides are gone in the old steel bin, they are of no use for the 924 guys right ?
937 trackday car
Series 2 engine
Fast road camshaft
Raceboy
PostPosted: Mon Dec 03, 2012 12:34 am    Post subject: Reply with quote
Yes, but I would use the 951S #8 hotside for other purpose.
'67 911 2.4S hotrod
'84 928 S, sold
'91 944 S2, sold
PostPosted: Mon Dec 03, 2012 12:47 am    Post subject: Reply with quote
Those are for the water cooling circuit. I'm not positive which is inlet vs. outlet, but you can see from the pix in this thread that on the side with two ports, one of them should be plugged.
peterld
PostPosted: Tue Dec 04, 2012 12:47 am    Post subject: Reply with quote
Ah thank you again Mr. Beckett!!!!
I just can't believe it's FOUR years ago that you organised Majestic to build me that hybrid turbo, and it took me another three to get the whole kit and kaboodle installed (prematurely it would seem).
I had completely forgotten about those posts!
If I had to take a guess then I would think the single port on the one side would be the inlet (as best as I can figure from the 951 PET), and the top of the two on the other side is the outlet.
Again having a guess, I would think that inlet/outlet orientation is probably not critical (I don't recall seeing any particular directional vanes inside).
Now to confirm size and thread pitch; and I might finally get it all together. Might try a post in 'general discussion' to reach out to any 951 owners for a piccie or two of the 951 installation.
Email sent.
80/81 932/8 ROW
