getting wet
rockhound72
PostPosted: Mon Nov 12, 2012 9:09 am    Post subject: getting wet Reply with quote
My '79 924 just started leaking from somewhere on the driver side. Where is this coming from?
PostPosted: Mon Nov 12, 2012 10:43 am    Post subject: Reply with quote
Clouds?
staticsan
PostPosted: Mon Nov 12, 2012 11:08 am    Post subject: Reply with quote
I'd suspect the windscreen seal. Have you stuck your head under the console to see if you can find where it's leaking?
Wade.
'82 British NA - Which I think I've been very lucky with!
Harm
PostPosted: Tue Nov 13, 2012 3:26 am    Post subject: Re: getting wet Reply with quote
rockhound72 wrote:
…Where is this coming from?
Maybe this?
Underneath your windshield wiper motor sits a drain that will delete excess water. Overtime this pipe that
connects to the firewall might get blocked by debris and leafs and such, and will rust from the inside out.
Outside bing inside your Toofah… and you'll end up having wet feet.
HTH
Regards, Harm.
Edit01
rockhound72
PostPosted: Tue Nov 13, 2012 8:27 am    Post subject: Reply with quote
Well, both areas seem like likely suspects. I figure I will just seal them both. Thinking about the flex seal spray stuff. As far as sealing the clouds......I'm just s.o.l. on that one Thanks for the help.
