tyfighter123
Posted: Tue Oct 30, 2012 7:16 am Post subject: Engine blocks? |
I am wondering if the blocks are the same for a turbo and an N/A? _________________ Porsche 924 1977 N/A
Mustang GT/CS 2007
Porsche 911S 1976
Porsche 931 1980
Porsche 931 1980 (parts car) |
Joined: 29 Jul 2001 Posts: 9131 Location: Royal Oak, MI, USA
Posted: Tue Oct 30, 2012 8:03 am Post subject: |
Pretty close, enough to be fairly swappable, yes... but not identical. _________________ Vaughan Scott
gegge
Posted: Tue Oct 30, 2012 8:09 am Post subject: |
Yes. Close enough. _________________ Carl Fredrik Torkildsen
!tom
Posted: Tue Oct 30, 2012 3:53 pm Post subject: |
What's the difference? Other than the number stamped into the block? _________________ 78 924 NA
5-lug |
peterld
Joined: 10 Dec 2006 Posts: 987 Location: Noosa Heads QLD Australia
Posted: Tue Oct 30, 2012 10:45 pm Post subject: |
Not necessarily.......very early NA blocks had different sized crank thrust bearing, so not interchangeable with later models. All later (post 1978 ) blocks are near as damnit interchangeable. _________________ 80/81 932/8 ROW |
McGyver
Joined: 24 Feb 2009 Posts: 354 Location: Jelenia Gora - Poland
Posted: Wed Oct 31, 2012 7:14 am Post subject: |
They're interchangeable if you take block from 78-79 upwards than it can be used to build 931 engine. Mine block comes from n/a and I didn't noticed any changes other than breather output which is different but can be changed easily. So if you want to use 924 n/a block to build 931 engine all should be fine and without any problems (only that 76 blocks had another crank diameter so watch for that). _________________ 931 82' - 5000km after full engine rebuild
SOLD: 924 81' N/A- with turbo gearbox "dogleg" - great but mysterious car
www.mauser98k.internetdsl.pl - if someone like german rifles (English version avalible) |
