Engine blocks?
tyfighter123
PostPosted: Tue Oct 30, 2012 7:16 am    Post subject: Engine blocks? Reply with quote
I am wondering if the blocks are the same for a turbo and an N/A?
Porsche 924 1977 N/A
Mustang GT/CS 2007
Porsche 911S 1976
Porsche 931 1980
Porsche 931 1980 (parts car)
PostPosted: Tue Oct 30, 2012 8:03 am    Post subject: Reply with quote
Pretty close, enough to be fairly swappable, yes... but not identical.
gegge
PostPosted: Tue Oct 30, 2012 8:09 am    Post subject: Reply with quote
Yes. Close enough.
Carl Fredrik Torkildsen
!tom
PostPosted: Tue Oct 30, 2012 3:53 pm    Post subject: Reply with quote
What's the difference? Other than the number stamped into the block?
78 924 NA
5-lug
peterld
PostPosted: Tue Oct 30, 2012 10:45 pm    Post subject: Reply with quote
Not necessarily.......very early NA blocks had different sized crank thrust bearing, so not interchangeable with later models. All later (post 1978 ) blocks are near as damnit interchangeable.
80/81 932/8 ROW
McGyver
PostPosted: Wed Oct 31, 2012 7:14 am    Post subject: Reply with quote
They're interchangeable if you take block from 78-79 upwards than it can be used to build 931 engine. Mine block comes from n/a and I didn't noticed any changes other than breather output which is different but can be changed easily. So if you want to use 924 n/a block to build 931 engine all should be fine and without any problems (only that 76 blocks had another crank diameter so watch for that).
931 82' - 5000km after full engine rebuild
SOLD: 924 81' N/A- with turbo gearbox "dogleg" - great but mysterious car
www.mauser98k.internetdsl.pl - if someone like german rifles (English version avalible)
