dpw928
Posted: Sat Oct 13, 2012 11:29 pm Post subject: |
Try retarding ignition by a few degrees (turn distributor clockwise) to see if that helps. If too advanced it can slow down the cranking rpm and cause a cold nonstart. Removing one spark plug lets it crank faster allowing the other cylinders to start.
78 928 5 sp Silver
78 928 AT Euro Black |
rat
Joined: 02 Nov 2004 Posts: 92 Location: Colchester, Essex, UK
Posted: Sun Oct 14, 2012 5:11 am Post subject: |
| Interesting theory. It could just about tie up with the observations I've made. I.e. that a tired battery added to the likelihood of non-start, and the sole observable difference between 3 and 4 plugs present was a slight increase in cranking speed. |
Posted: Sun Oct 14, 2012 10:25 am Post subject: |
CSV should run about 8 seconds IIRC.
If you connect an earth to red/white cable with a switch this will enable you to fire it at will. (use only for testing) _________________ Porsche 924 1984 (UK import) NA
Muz924
Joined: 21 Jul 2010 Posts: 137 Location: Melbourne Australia
Posted: Tue Jun 25, 2013 4:20 pm Post subject: |
The weather has turn cold and an old problem has re-surfaced!
After starting normally over summer, my no start problem is back
I get strong cranking with no fire, I tried the pulling out spark plug #1 and still no start.
I am getting no spark and hence no fuel pump starting. I get 10.5v at +coil when cranking but no voltage at -terminal of coil.
I swapped over to an old coil and she fired up with problems, re-connected to new coil and she starts up OK!
Problem occurs with both coils and is fixed only by swapping them around.
The problem must be before the -terminal of the coil which would be ignition control box or distributor.
Any ideas would be appreciated.
I am running the standard 1980 breakerless (no points) type distributor.
Santo _________________ 1978 924 RoW 5-Speed (Current Project)
1980 924 RoW 5-Speed (Donor Car)
1985 Alfa Romeo Alfetta GTV 2.0 (Previous Project Car) |
Ponz
Posted: Tue Jun 25, 2013 10:44 pm Post subject: |
make sure the wires are on right firing order. _________________ 77 1/2 track car
79 931 Euro
87 911 Targa |
Ponz
79 931 Euro
87 911 Targa |
Muz924
Posted: Sun Jun 30, 2013 7:28 pm Post subject: |
Yeah, the wires are spot on, when it starts its runs perfectly.
Started up fine this morning....starting to do my head in
Next time it plays up i will check and see whats happening at the ignition control box.
Muz924
Posted: Sat Jul 27, 2013 7:54 pm Post subject: |
Ahhh, this is doing my head in!!
The problem keeps on changing, currently it starts up it runs on three cylinders.
I have narrowed it down to no spark at No.4.
I have replaced spark plug, lead & even swapped around 3 differant coils...still same problem.
The only way i can get No.4 to spark is by removing the lead from the distributor cap & once i have approx 10mm gap i get a big spark and the engine runs nice and smoothly of all 4 cylinders. When i move it closer or connect it back onto the distrubutor cap the spark stops again.
Does anyone have any ideas whats going on? _________________ 1978 924 RoW 5-Speed (Current Project)
dpw928
Posted: Sat Jul 27, 2013 11:32 pm Post subject: |
Have you checked the interior of your distributor cap for cracks or signs of arcing? Also, have you checked your valve and ignition timing?
78 928 5 sp Silver
Muz924
Posted: Sun Jul 28, 2013 4:02 pm Post subject: |
Hi Dennis,
All the "consumable" parts are new, valve clearances were ok last time i checked, It starts and runs fine in the warmer weather.
I don't understand why i need to make the High Voltage jump through a 10mm gap to get it to spark plug to fire.
In other words it prefers a higher resistance to fire.
I cant help thinking its a faulty ignition module, unfortunatley i dont have spare one to interchange.
Looks like i am going down the MSD ignition path.
Cheers _________________ 1978 924 RoW 5-Speed (Current Project)
Muz924
Posted: Mon Aug 12, 2013 9:24 pm Post subject: |
OK,
I think i might have solved the problem
I kept swapping plugs & leads until i got the problem to re-occur on a different cylinder. Problem seems to have been the spark plug!! What stuffed me up was the plug that i was swapping around was also faulty.
So i had 3 good & 2 bad (NGK BP6ES) i was rotating around.
I kept getting a crap orange spark with the plug out and sitting on valve cover. I then grabed an old Bosch WR6DC i had in a box of old spare parts and got an good strong blue spark. I put it in and she starts and runs on all four
Tried it again today and it starts and runs OK.
The car is not registered yet and so I start it up once a week making sure it warms up with the thermo fan kicking in and out.
I guess this can stuff up spark plugs as all the NGK plugs i have I bought new with no real driving done on them!
1 step closer to getting on the road ! _________________ 1978 924 RoW 5-Speed (Current Project)
Muz924
Posted: Wed Jun 25, 2014 10:14 am Post subject: |
Ahhhh,
Weather has turned COLD here in Melbourne Aus & my no spark when weather is cold has returned!!!
The car has been starting first time every time over the warmer months.
I still think its the ignition control box, might get an MSD and give that a go.
Cheers
Santo
Gave her a polish the other day....at least she looks good!
Posted: Wed Jun 25, 2014 4:22 pm Post subject: |
Maybe you could borrow that box from someone else for a quick try?
When something mallfunctions why think of modifications? why not just replace the bad part and keep the car original. _________________ Supercharger and EFI kits
Posted: Fri Jun 27, 2014 7:35 am Post subject: |
I took the box off mine and it had rusty screws holding it on.
As this is also how it gets it earth ( none in the wiring) I replaced them. I also fitted an earth wire to the body of the box to chassis. _________________ Porsche 924 1984 (UK import) NA
pmcaya2
Joined: 24 Nov 2005 Posts: 191 Location: Scio, NY USA
Posted: Sun Jun 29, 2014 1:46 pm Post subject: |
I'm somewhat hesitant to suggest this, but its a quick and easy check.
Since you start the car periodically and don't drive it in weather - I wonder what would happen if you start the car and gently spray water on the engine with a garden hose. If it starts to miss or die, you'll know the problem is electrical.
One other check: swap out the coil wire - it does 4X the work as the plug wires and failure sometimes gives hard to diagnose problems.
I hope this helps. - Peter |
