oil pressure relief valve
bgammie1
PostPosted: Wed Oct 10, 2012 12:27 pm    Post subject: oil pressure relief valve Reply with quote
would like to replace my oil pressure relief spring and piston
does anyone know where I can go to purchase these parts?
BFG
1982 Porsche 924 NA
!tom
PostPosted: Wed Oct 10, 2012 1:08 pm    Post subject: Reply with quote
Do some searching. I believe the spring is NLA, and I recall some discussion about trying to determine a suitable replacement.
78 924 NA
5-lug
bgammie1
PostPosted: Wed Oct 10, 2012 1:17 pm    Post subject: Reply with quote
did some searching
ie, jim elles porsche (dealer) parts, auto atlanta, found it was NLA
That is why I am asking board/forum members for assistance
BFG
1982 Porsche 924 NA
daniel
PostPosted: Wed Oct 10, 2012 1:53 pm    Post subject: Reply with quote
Why do you want to replace it? If you dont have enough oil pressure, whack a shim under the spring. While your there, check the condition of the bore. If it is worn out of round the piston can get stuck which could cause too much or not enough oil pressure.
1989 944 Cabriolet
!tom
PostPosted: Wed Oct 10, 2012 1:56 pm    Post subject: Reply with quote
bgammie1 wrote:
did some searching
I meant searching on the forums here regarding the possibility of a suitable replacement for the NLA part.
78 924 NA
5-lug
