1981 924 turbo starts up then dies
jeffrey924
PostPosted: Sat Oct 06, 2012 5:33 am    Post subject: 1981 924 turbo starts up then dies Reply with quote
New to the forum, trying to bring the car back form the dead i saw a few other posts about this but didnt really help me out.i just replaced the fuel pump and i hear it running? Whats my next move?
Thanks
Jeff[/list]
PostPosted: Sat Oct 06, 2012 5:53 am    Post subject: Reply with quote
You drained the fuel tank, right?
Your jobs:
1. Timing belt and tensioner, ASAP.
2. Obtain a CIS pressure tester, check system and control pressures.
3. Carefully inspect engine for vacuum leaks.
4. Leak-down test would not hurt.
Good luck.
jeffrey924
PostPosted: Sat Oct 06, 2012 7:27 am    Post subject: Reply with quote
Yes i did drain the fuel tank and replacedit with new gas, I am going to order the timming belt next paycheck but i want the car kinda running before i do that. Where would i find a cis pressure tester? I took out the air box it was in really shitty shape so i do have a one inch air linethat leads to no where? How would i go about doing a leak down test?
PostPosted: Sat Oct 06, 2012 8:39 am    Post subject: Reply with quote
jeffrey924 wrote:
...I am going to order the timming belt next paycheck but i want the car kinda running before i do that.
How expensive might this get..?
PostPosted: Sat Oct 06, 2012 8:43 am    Post subject: Reply with quote
If you think you are going to spend $50 per paycheck to revive and daily drive a "RWP" 931, you are sadly mistaken.
PostPosted: Sat Oct 06, 2012 1:18 pm    Post subject: Reply with quote
Well enjoy the snapped timing belt and the broken engine.
Timing belt is damned cheap fom RockAuto.com. Much cheaper than a set of valves.
Spend the week fixing electrical connections (all the grounds especially) and getting the engine ready for the timing belt change along with the various hoses.
dpw928
PostPosted: Sat Oct 06, 2012 11:31 pm    Post subject: Reply with quote
+ 1 on the timing belt. On your fuel issue, it is starting on fuel provided by the cold start valve but it only injects fuel for a few seconds. It sounds like your injectors are plugged or the plunger in the fuel distributor is stuck. The same thing occured on my 81 that had sat for 5 years. I was able to clean the injectors by spraying cleaner into the inlet (after removal) and using 60 psi compressed air to force the cleaner through the injector. Repeat until you get an even conical spray pattern. To clean the distributor, I removed all the banjo fittings for the injectors and control pressure line and sprayed cleaner into each port. Let the cleaner sit, then repeat. Also, remove the relief valve on the fuel distributor and spray cleaner into the port. This got mine running but it required 2 or 3 tanks of fuel with cleaner to finish up and get it running right.
Dennis
81 931 5 sp
78 928 5 sp Silver
78 928 AT Euro Black
jeffrey924
PostPosted: Sun Oct 07, 2012 9:14 am    Post subject: Reply with quote
thank you dpw928
and I just got back from Los Vegas so money is super tight right now.
Where would be the cheapest place to buy a timing belt
PostPosted: Sun Oct 07, 2012 11:01 am    Post subject: Reply with quote
Anyplace, they are only ten bucks or so.
jeffrey924
PostPosted: Wed Oct 10, 2012 8:42 am    Post subject: Reply with quote
okay so today i changed the timing belt and blew air through all the injectors and lines for the fuel, changed spark plugs and wires and still starts up then dies now i went a step further and too out all the injectors and layed them on the head to make sure the fuel was coming out in a mist which it did. then stopped. so i put the injectors back in and left the turbo inlet off and had the car running off carb cleaner. what do you guys think?
PostPosted: Wed Oct 10, 2012 8:54 am    Post subject: Reply with quote
How about if you hold the key in the crank position? Does it die when you release the key?
If so, your ignition switch is broken (specifically the plastic switch that attaches to the back of the tumbler section)'
Otherwise, go through the 931 resurrection thread and bypass the fuel relay, the boost pressure switch, etc. and try again.
jeffrey924
PostPosted: Wed Oct 10, 2012 9:11 am    Post subject: Reply with quote
that makes sense but im only 80% sure so im going to run to my garage and go double check
thank you!!
if this is true, where would be the cheapest place to buy an ignition switch?
kcoyle
PostPosted: Wed Oct 10, 2012 9:18 am    Post subject: Reply with quote
Any chance this is the car that was going to be a 24hr of lemons car?
Also, this.
http://www.924board.org/viewtopic.php?t=28790
jeffrey924
PostPosted: Wed Oct 10, 2012 10:00 am    Post subject: Reply with quote
haha, but in all reality I took all the Fuel injectors out and the the car started with all the fuel dripping into it. and as i watched the injectors they all shot fuel at the same time kinda like pulsating is this right?
PostPosted: Wed Oct 10, 2012 10:35 am    Post subject: Reply with quote
For CIS, yes.
You should find some books on the subject of CIS before you go much further.
