944 alloy wishbones do not fit!
19marty73
PostPosted: Thu Sep 06, 2012 7:02 am    Post subject: 944 alloy wishbones do not fit! Reply with quote
OK so after building my coil overs some of you noticed the wish bones on my car were not standard. They are of course 1985 944 alloy wish bones. I bought them because I'd read on here that they fit, do they bollox! I hope you can see in the picture the different diameters of the bushes where they mount into the cross member.
I know you can't read the scale on the vernier but there is about a 5mm difference between the steel and alloy bushes. The reason these will bolt on to the 924S is because it has the alloy cross member to support the 2.5 engine. The only way to get these to fit was to get the flap wheel out and grind about 2mm off the casting.
Now I'm no mechanical engineer, but I don't think I've removed too much strength. EEEEKKKKK! I bought OEM drop links and aftermarket upraighted bushes. The bush kit was specially made up for me because I wanted to keep the 20mm front ARB (I have no rear ARB so didn't want to induce understeer by fitting a thick front ARB) and the ends of the 20mm ARB are only 16mm. 944 drop links are normally 18mm.
The bush kit unfortunately came with cheapo flat penny washers for the drop links (top left) so I forked out again for some OEM curved washers and nylocks.
When fitted they blow the pants off the standard steel A arms looks wise. Probably not as strong as steelies but hey ho. Tune in next week for my vented big brake conversion using audi parts. More back street engineering!
Dutch924-racer
PostPosted: Sat Sep 08, 2012 5:14 pm    Post subject: Reply with quote
Is this form the steel arms ore the alloy ones ?
937 trackday car
Series 2 engine
951S turbo and intercooler
Fast road camshaft
PostPosted: Sat Sep 08, 2012 8:41 pm    Post subject: Reply with quote
There is another way, and this issue has been discussed before, most recently here:
http://www.924board.org/viewtopic.php?p=324484#324484
19marty73
PostPosted: Sun Sep 09, 2012 5:54 am    Post subject: Reply with quote
Hi Dutch924-Racer. They are the ones off the 951 arm.
joejax
PostPosted: Sun Sep 09, 2012 10:12 am    Post subject: Reply with quote
Cool. Any pics of the car? How about with the new wheels?
I got nothin'
Uhhh...you got any pics?
PostPosted: Tue Oct 30, 2012 2:46 am    Post subject: Reply with quote
Wow,that piece of aluminium is what i need right now for my 944S2.
(Left side)Anyone sitting on a spare which is in good condition?
(No play on the knuckle...)
daveo
PostPosted: Sun Dec 02, 2012 2:33 am    Post subject: Reply with quote
hi just looking at your post, i was toying with the same thing.
the arm stiks out longer with the aloy arm, haw did this efect the front wheel placment for fiting in the arches
thanks
Dave
