Headlight ideas
Bockscar
PostPosted: Wed Aug 15, 2012 2:42 am    Post subject: Headlight ideas Reply with quote
Hey Folks.
I want to modify my headlights. I see lots of people take the buckets out and put recessed lights in, but I think that looks kind of fruity and I think one of the things that make the 924 unique is that it has those pop-up lights. This design I think inspired many automakers to make cars that have similar design cues.
Has anyone here put in aftermarket lights, such as the ones from eBay? They even sell halo/angel eye lights . I'd be curious to see what those look like on our cars.. I can't imagine they would look very good. One idea I've been tossing around is building a new bucket to house 2 smaller lights (http://www.evo-r.net/product/RX-7/CIMG4467.JPG) My fear with this is that the buckets for our lights are really big, and having two small lights in there might look really strange. Perhaps using long, narrow lights instead?
Brian
'79 924 - Restoration In Progress
'81 924 Turbo w/EFI - Scrapped
PostPosted: Wed Aug 15, 2012 5:22 am    Post subject: Reply with quote
If you do some searches on the web, particularly on Rennlist and Pelican, you can find examples of guys who have done similar conversions and modified the lift mechanism so that it only goes up part way. This overcomes the issue of the headlight surround being square and having a narrow line of smaller lights.
In my opinion, though, this just ends up looking goofy, like a heavy-lidded or sleepy look. I think it's because of the dual angle on the headlight cover...when it's not up all the way, the angle at the front of the light cover is all wrong, like tilted down instead of horizontal.
When I first started thinking about headlight mods on my own projects, I was all hot to do dual projectors in a fixed headlight conversion. But the longer I've stayed with these cars, the more I really do not like modernizations to the classic lines. It's just my personal opinion, but modern wheels, modern ground effects, and other such modernizations to the cosmetics of the car almost always look bad.
A lot of it may be due to the poor execution of most owners who attempt them...so you shouldn't be dissuaded from trying...but I think Porsche really got it right when it comes to all the little details on the styling of these cars. I really like leaving the headlights and taillights alone...or at most doing the classic fixed headlight conversion as with the GTS or GTR. Everything else I've seen just doesn't quite cut it.
Catamax944
PostPosted: Fri Aug 17, 2012 11:21 pm    Post subject: Reply with quote
Deutsch nine did something like that ,looks ok but for the price i really don't think it's worth it http://www.deutschnine.com/mm5/merchant.mvc?Screen=PROD&Store_Code=porsche-transaxle&Product_Code=D9-944II951S2-DHLK&Category_Code=porsche-transaxle-944-turbo-s2-aero-dynamics
'86 944 Club Sport replica
www.cardomain.com/ride/3094204
Bockscar
PostPosted: Sat Aug 18, 2012 1:48 am    Post subject: Reply with quote
I saw that actually! The pictures make it look like the lights are pointing downwards, which make it look a bit odd. But that is very similar to what I had in mind. My primary concern is that since the headlights, when they are fully open, are much taller than they are wide, even if I rigged the motor to only have them pop up half way, I'm afraid it would look a little strange.
Brian
Bockscar
PostPosted: Sat Aug 18, 2012 2:03 am    Post subject: Reply with quote
I find it extremely interesting you say that about the 924 because the car was originally intended to be the flagship VW sports car of the time. While the car was designed and produced by Porsche, it was designed with specifications provided by VW, which is probably why the 924 looks nothing like any other Porsche of the era (including the 928) and looks an awful like other VWs of the era (such as the B1 Passat and especially the Scirocco).
Brian
PostPosted: Sat Aug 18, 2012 6:30 am    Post subject: Reply with quote
Really? I have seen vw cars of that era...none have round bodies...all have sharp corners...i've owned an 85 audi it hase NOTHING to do with the 924
I think that even thar ugly 924 prototype looks nothing like any vw...but nothing like the 911 too
Bockscar
PostPosted: Sat Aug 18, 2012 7:58 am    Post subject: Reply with quote
The original Porsche 924 came out in 1976. Compare a 76 924 to a 76 Passat and then to a 76 911. Porsche designed the 924 to look congruent with VW's design style at the time. For example, look at the 914 (technically a Porsche/VW project) and the 911. Very sleek and round. Then look at the 924. Not exactly sleek or rounded. Not quite as square or boxy as a Passat, but its very clear Porsche tried to make the 924 look as close to VW's auto line as they could.
Brian
snakoil
PostPosted: Tue Aug 21, 2012 2:16 am    Post subject: Reply with quote
back when I had an isuzu piazza (isuzu impulse) with round headlights like on the 924, the hype was to change to globe with a suzuki bike light or bmw since those allowed mounting of a H1 bulb
for there you can get yourself an HID kit and make a conversion.
you would improve your lighting and not kill the stock look.
I have hard time finding the link between the B1 passat and 924
1979 924 NA
Bockscar
PostPosted: Tue Aug 21, 2012 4:37 am    Post subject: Reply with quote
It's funny you say that because I see a huge resemblance. Put the 924's front end on the Passat, remove the rear doors and shorten it up a bit. Porsche originally designed the 924 to fit into VW's line up. Whilst Porsche did modify many things after they purchased the rights to produce the car back from VW, the 924 is still very much a VW-esque car.
Brian
PostPosted: Tue Aug 21, 2012 7:32 am    Post subject: Reply with quote
To each his own...but I also see no resemblance between the 924 and the VW Passat or Scirocco (or any other VW). In the case of Passat vs 924: Four door vs two door. Square hatch vs. bubbled glass. Dual fixed headlights vs single concealed headlights. Squared vs. Pointed nose. Wheel arches have completely different lines. The VW window lines are all completely angular (triangles or squares) whereas the 924 has rounded shapes. The 924 has completely different break lines in the body sheet metal. There is almost nothing similar about the two cars other than they were 4-bangers with a hatch.
Even the Scirocco looks completely different, although it follows a similar layout and formula, if not completely different lines.
Regardless of starting its life as a VW project, the 924 body work was indeed designed by Porsche from the get go, and is uniquely Porsche in aesthetic.
In fact, if you do your homework, you will see that Mr. Lagaay, the designer of the 924, never did any design work for VW, but in fact was on the 911 design team, as well as the 968, 993, 996, and others.
To say that the 924 and 928 do not resemble each other is also a very strange comment to me, as they look more alike (especially with the 968 interposed between them) than do the VW siblings Passat & Beetle (incidentally, the latter being another Porsche design).
We're all entitled to our opinions.
Bockscar
PostPosted: Tue Aug 21, 2012 9:35 am    Post subject: Reply with quote
Indeed. I come to the 924 from the world of old Volkswagen cars and I see many, many similarities each time I work on it. Here's an interesting article that looks at the "The 924 isn't a Porsche" argument from a different point of view - http://www.thetruthaboutcars.com/2010/08/porsches-deadly-sin-5-engineering-project-ea-425/
Brian
PostPosted: Tue Aug 21, 2012 9:44 am    Post subject: Reply with quote
I didn't say there weren't similarities...there certainly are, particularly since they share a lot of common components...and in many regards to the benefit of us enthusiasts who are trying to keep these 30-year old Porsches on the road!
But from a design / aesthetic perspective? That's where, in my opinion, there is very little similarity.
Bockscar
PostPosted: Tue Aug 21, 2012 9:55 am    Post subject: Reply with quote
Well, ok true. The way I look at it is, you can certainly tell just by looking at it that the car was designed and produced in Germany.. Older German cars just have that look. I happen to think older VW (And some BMWs) look killer. Older American or Japanese cars? Not so much, imo. On the other hand, I see more similarities when I compare a 924 to that Passat than I do a BMW 2002 or 3 series, for example.
Brian
Harm
PostPosted: Tue Aug 21, 2012 11:00 am    Post subject: Re: Headlight ideas Reply with quote
…and let us not forget Anatole Lapine!
Porsche (studio) and Giorgetto Giugiaro are two totally different galaxies.
Anyway…
no
yep
Though …Brazil:
VW Germany couldn't stand it!
BTW: The early 924 clay models remind me of the Daytona
HTH
Raceboy
PostPosted: Tue Aug 21, 2012 5:46 pm    Post subject: Reply with quote
One could always buy clear lens headlights meant for Golf 1, which are bolt on and provide much-much better lighting. They are cheap also, I bought mine for ~25 euros a piece.
Look very nice also and if one would want, they are available as tinted too.
'83 924 2.6 16v Turbo, 470hp
'67 911 2.4S hotrod
'90 944 S2 Cabriolet
'78 924 Carrera GT replica
'84 928 S, sold
'91 944 S2, sold
'82 924S/931 "Gulf", sold
'84 924, turbocharged, sold.
