serz
Posted: Tue Jul 31, 2012 2:48 pm Post subject: rear lights electric problem |
Hi, brake light does not work - everything elese OK. Where you would start to look at? _________________ ex Porsche 924 1978
ex Porsche 924 1982
Now Porsche 924 turbo
http://www.thebestporsche.com |
Posted: Tue Jul 31, 2012 10:36 pm Post subject: |
In this order:
1. Check for blown fuse
2. Check for blown bulbs
3. Clean connections at light clusters
4. Clean ground at rear center of chassis
5. Check connections at brake light switch (will be on the pedal stop or the master cylinder depending on what model year your car is) _________________ erstwhile owner of just about every 924 variant ever made |
serz
Posted: Wed Aug 01, 2012 12:58 am Post subject: |
hi, thanks, checked everything except connector on master cylinder
is there any relay, or only fuse?
maybe there is fuse diagram, which one does what? 931 s1 eudm _________________ ex Porsche 924 1978
ex Porsche 924 1982
serz
Posted: Sat Aug 04, 2012 2:42 am Post subject: |
there are two connectors on the main brake cylinder - one facing down, another - sideways. which one does what?
and thanks, after reinspecting those two, rear lights came to life  _________________ ex Porsche 924 1978
ex Porsche 924 1982
Posted: Sat Aug 04, 2012 2:48 am Post subject: |
I believe they do the same thing.
There is sometimes a connector on the reservoir cap itself for a fluid level indicator as well. _________________ Stefan
