Car randomly dies while driving..
Coolbri1191
PostPosted: Thu Jul 19, 2012 3:29 pm    Post subject: Car randomly dies while driving.. Reply with quote
I'm at a loss here guys.. I think either my speed or reference sensors are bad, but I don't know which one it could be. This is the only thing I can think of that is making the car randomly die.
Yes, I have replaced the DME relay 2 years ago with a brand new one. Yes, I made the jumper wire for backup. Same results...
Fuel pump was replaced in 2007. Fuel filter in 2007, then again in 2010.
It seems to happen between 10-30mph. I haven't experienced it yet on the freeway, but it seems to be getting worse and worse, happening more frequently, which is why my initial thought was the DME relay.
Temperature has no effect; cold engine, warm engine, hot weather, cold weather.
The way it dies, is as if the fuel pump just gives out. A total loss of power and then the car tries to run on no fuel. Sometimes it will start right back up no problem, but I usually end up with a dead car coasting in neutral to a stop with the alternator light and oil light on.
Guards Red 1987 Porsche 924S (Automatic)
2001 Ford Explorer Sport (DD)
joecitizennn
PostPosted: Fri Jul 20, 2012 5:40 am    Post subject: Reply with quote
lots of possibilities. Check your fuel pump FUSE (not relay) for corrosion on the tips. Speed and refrence sensor function can be checked at the DME plug. I will try to find a link...
87 924s
88 924SE gone
447 hp cgt clone
87 924S gone
84 944 sold
83 944 sold
89 turbo S LSD, ABS etc
86 951 white rocket
85 944 sport everything.
84 944 sold.
87 944 sold
joecitizennn
PostPosted: Fri Jul 20, 2012 5:44 am    Post subject: Reply with quote
Here is a link describing speed and refrence sensor check.
http://www.924board.org/viewtopic.php?t=36094&start=0
Make sure to click the link within the above link that shows the DME pinout.
87 924s
88 924SE gone
447 hp cgt clone
87 924S gone
84 944 sold
83 944 sold
86 951 white rocket
84 944 sold.
87 944 sold
joejax
PostPosted: Fri Jul 20, 2012 6:03 am    Post subject: Reply with quote
"Car randomly dies while driving..."
I thought that was normal for a 924.
Sorry...
I got nothin'
Uhhh...you got any pics?
Coolbri1191
PostPosted: Fri Jul 20, 2012 6:31 am    Post subject: Reply with quote
I saw this thread a while back of someone checking their fuel pump fuse in which it LOOKED okay.. until they pulled it out.
This one has to go in the record books..
Check it out! This is my fuel pump fuse.
joecitizennn
PostPosted: Sat Jul 21, 2012 1:23 am    Post subject: Reply with quote
Yeah, that was me. One of the reasons you pull the fuses out and check the ends.
joecitizennn wrote:
The other day one of my 924Ss did not start. This seems to be a common complaint about these cars lately.
I was interested to find after some checking that it was the fuel pump fuse. But the way it failed was what got me. It did not blow, rather it eroded at the contact over time. It was impossible to tell it was bad visually without removing it.
Good fuse?
I think not!
87 924s
88 924SE gone
447 hp cgt clone
87 924S gone
84 944 sold
83 944 sold
86 951 white rocket
84 944 sold.
87 944 sold
Coolbri1191
PostPosted: Sat Jul 21, 2012 5:10 am    Post subject: Reply with quote
Well, as it turns out anyways, the car died on me again on my way home. I was sitting at a light. Back to square one..
Coolbri1191
PostPosted: Fri Aug 03, 2012 11:59 am    Post subject: Reply with quote
So what I noticed is if the car doesn't start or it dies, smacking the crap out of the dme computer gets it to start up and run again. I've tried tapping the relay in hopes the vibrations from when hitting the computer was actually making it start, but it didn't make a difference. So if I take apart the computer what should I look for? Bad joints? Any common areas where these go bad?
edredas
PostPosted: Fri Aug 03, 2012 2:15 pm    Post subject: Reply with quote
Sorry, I don't have a better picture, but check the solder joints where this connects to the board.
'84 944 -Red, Automatic
'87 924S -Red, 300hp 951 swap
'87 924S -Red, Project Car
'88 924S -Red, Daily Driver
Coolbri1191
PostPosted: Fri Aug 03, 2012 4:16 pm    Post subject: Reply with quote
Okay, will do. Would that be a possible cause to random dieing?
edredas
PostPosted: Fri Aug 03, 2012 4:44 pm    Post subject: Reply with quote
Yep, it would cause just what you've described.
You can't always see the cracks, so be sure to reflow these joints no matter how they look.
Coolbri1191
PostPosted: Fri Aug 03, 2012 6:00 pm    Post subject: Reply with quote
Okay, thanks man, you come to the rescue AGAIN for me! you rock. Can't wait to tear that thing apart. If I find anything funny, I'll post a pic.
Coolbri1191
PostPosted: Sun Aug 05, 2012 6:35 am    Post subject: Reply with quote
Okay, I got the DME apart, found the solder joints you mentioned and low and behold.. 2 of those 3 joints are cracked in a circle. I tried getting a picture but they all came out bad. I have one decent picture if anyone wants to see it, but it's definitely cracked.
edredas
PostPosted: Tue Aug 07, 2012 1:24 pm    Post subject: Reply with quote
How did it turn out, did it fix your problem?
Coolbri1191
PostPosted: Tue Aug 07, 2012 1:37 pm    Post subject: Reply with quote
So far so good! Did a test run, hit the computer a few times to see if it would die, and everything is great so far. I re-soldered pretty much the whole board, including the 3 bad ones. Thanks for all your guys' help!
