isuras2
Posted: Wed May 30, 2012 9:49 am Post subject: Engine Fuel Lines |
I have a co-worker with a 924S. He has a fuel leak from either the fuel line (part number 944-356-943-03 or 944-356-945-03) and needs it replaced. Is there a way to replace the lines with new ones for cheaper than $200+ that most parts places want? _________________ Rob
'80 931 (sold)
'80 924 NA (sold)
Former Omaha Crew |
mehall
Joined: 15 Dec 2008 Posts: 191 Location: Richmond, MO
Posted: Wed Jul 11, 2012 10:19 pm Post subject: |
When I bought my '87 there was a brass line spliced in the fuel line right over the intake structure. It was a bullet casing with the primer cut off.
Don't know how long it had been there. I noticed the line was soft there, so I cleaned it up and replaced the brass with copper line using double camps each end.
It still holds up. However, I don't recommend that for long. There is a long list of deferred maintenance that I've been working through for the past 3 years. (a stroke 2 years ago has slowed me down a bit ) If you use copper, be sure to check the line weekly at least because a fuel leak will blow up in you face. _________________ Mark
'87 White 924s manual
'94 Lexus LS400
www.kcws.org |
mehall
Posted: Thu Jul 12, 2012 1:18 pm Post subject: |
Thank you.
A much needed help and seems well thought out. _________________ Mark
'94 Lexus LS400
www.kcws.org |
Posted: Thu Jul 12, 2012 1:34 pm Post subject: |
In case anyone else was looking for this info later.....
Good luck! _________________ Stefan
Posted: Mon Aug 25, 2014 12:43 am Post subject: |
reviving old thread. Will the Rennbay kit fit the 924S? _________________ '83 944 Track car.
2001 Ford F350 powerstroke |
Posted: Mon Aug 25, 2014 2:07 pm Post subject: |
Yes it should. _________________ Stefan
edredas
Posted: Mon Aug 25, 2014 3:25 pm Post subject: |
Just from quickly looking at the website it appears that kit is for the late 944. I didn't see an early kit on the site, but if that is the one you are talking about, then it will work. The 924S uses the early fuel lines which are a little longer.
Also, you can just order the parts to make your own kit and save some money. I ran all new lines from the tank to the engine for less than the cost of these kits... just throwing that out there. _________________ '84 944 -White, Brown interior
'84 944 -Red, Automatic
'87 924S -Red, 300hp 951 swap
'87 924S -Red, Project Car
'88 924S -Red, Daily Driver |
