Stainless braided brake hoses
Matt-JPR
PostPosted: Sat Apr 07, 2012 5:19 am    Post subject: Stainless braided brake hoses Reply with quote
Hey guys, as i'm going to be doing work on my brakes soon (replacing seized rear wheel cylinders, adjusters, etc) would it be worth replacing the flexi hoses with standard rubber or with the stainless braided ones?
Its on a 2.0l n/a, dont do any track work with it yet but used most days.
I had tried a search on here too but it turned up lots of pages with nothing specific on this subject.
Any help or advice appreciated
Matt
PostPosted: Sat Apr 07, 2012 5:26 pm    Post subject: Reply with quote
They can help firm up the pedal feel slightly, allowing more finite control of the brake application at the limits of tire adhesion.
Plus they are slightly stronger, potentially longer lasting and better looking.
They are usually the first thing to go onto my used cars, just a matter of habit anymore.
PostPosted: Sun Apr 08, 2012 1:39 am    Post subject: Reply with quote
Downside: braided cover hides developing cracks, therefore the lines cannot be visually inspected for failure points like factory ones.
But, like Stefan, I have them on my cars anyway!
mikebola
PostPosted: Sun Apr 08, 2012 3:00 am    Post subject: Reply with quote
I asked around a while back and was told they'll fail a state inspection since you can't check for damage.
proud owner of a 1979 924 Sebring Edition with a 931 trans that looks horrible but somehow runs...
PorscheDrift
PostPosted: Sun Apr 08, 2012 1:50 pm    Post subject: Reply with quote
It depends on who you go to for inspection, most the time if it doesnt say DOT on the lines they will fail you if your mechanic is a dbag. If you do get the sb lines make sure they have dot approved on them if your afraid they wont pass. But most the cars ive seen have cracked lines like crazy and they pass just fine unless its leaking fluid. Really your just looking at pads and rotor thickness and that the e-brake holds. Rarely do we take off the drums to check rear shoe thickness long as the ebrake holds.
My old boss used to tell me not to bother too much with the lines as long as they held fluid or looked REALLY bad cause brake lines= brake flush= too much time on 1 car plus thats almost always a ordered part so it meant the car would be tieing up a lift for too long..... Be aware though if you have a small time mechanic they see anything that says poor-sch as they call it, they get dollar signs in their eyes.
But arround A-town you would be amazed what you see on the road that passes inspection.......
80 euro
82 usdm
and all kinds of rice
Brockoli
PostPosted: Mon Apr 09, 2012 9:15 am    Post subject: Reply with quote
I bought a set for my '80. Got them from EBS racing. Fit well and I think they had dot on them. Don't know how much they improved the pedal since I hadn't driven the car prior to rebuilding the brakes. I think it was well worth the $50.
Ian89C4
PostPosted: Tue Apr 10, 2012 2:57 am    Post subject: Reply with quote
I believe the Goodridge stainless steel lines are DOT approved. A little more expensive than $50, but from what I hear they are pretty good. I have ordered them up for the 924, but have not had a chance to put them on as I am out of the country.
I have them on the 911 and I could tell a much stiffer brake pedal the first time I drove the car after putting them on.
cheers,
Ian
Ian Edgerly
North Carolina
Current:
1980 924 Euro ("Wahala")
Matt-JPR
PostPosted: Sun Jun 03, 2012 8:53 am    Post subject: Reply with quote
A belated thanks for the replies guys i'm now doing the brakes and noticed that the rear rubber hoses seem to be shorter than the stainless ones i got, by a about an inch or 2. is this normal with after market sets?
Many thanks
Matt
1984 euro 2.0 N/A, Audi 80 4 lug wheels and 20mm spacers.
dubrict
PostPosted: Sun Jun 03, 2012 3:14 pm    Post subject: Reply with quote
Many thanks
Matt
An extra inch or 2 should be just fine, especially considering both sides will have the extra bit added. From what I've seen, that is pretty typical in those kits. Just make sure the extra length isn't gonna rub against any moving parts
1979 924 NA
2009 Chevy Impala
2005 Dodge Dakota
