Rails and injectors that work?
CorsePerVita
PostPosted: Thu Mar 29, 2012 6:30 pm    Post subject: Rails and injectors that work? Reply with quote
Does anyone have any good references to rails and injectors that are a straight fit for our engines for megasquirt conversions?
I've seen a lot of different posts but some don't list the rails, or others are years old and don't have the pics and stuff anymore.
I bought a stock rail off of a zetec but the way the rail fits is "ok" but the actual hard line coming off of the rail didn't end up being what I was looking for.
I'd like an inline style (i'm doing an in line fuel pressure regulator) so basically I'll just have the one line going to the rail and that's it. The return line on my setup will go from the reg back to the tank.
I'd like something that I can just bolt up and be done with it, if anyone knows of any, that would rock.
- 1980 Porsche 931 (Daily)
- 1987 Lamborghini Jalpa
- 1999 Ducati 900SS
PostPosted: Fri Mar 30, 2012 3:06 am    Post subject: Reply with quote
There isn't a bolt-on available. You have to make your own brackets. Ideola is working on a solution, but I don't think he's ready yet. The only other option that WAS available was from Endwrench, but he doesn't offer them anymore, but they come up for sale from time to time.
Your best bet is to buy a universal racing style rail for a Ford Zetec, etc which will be a straight piece of billet that you can use the proper fittings to adapt it to your needs.
Or wander the salvage yards with a ruler in hand measuring injector spacing and look for rails where the inlet/outlet match what you need and lend themselves to be adapted to the head.
Either way, hold down brackets will need to be fabricated to hold the rails in place.
fors example, here's a billet rail for a Focus:
http://www.rsaperformance.com/obx-fuel-rail-billet-00-04-ford-focus-zetec-zx3-zx4-zx5.html?12476
That should work, once you have some brackets fabb'd up.
mikebola
PostPosted: Fri Mar 30, 2012 3:21 am    Post subject: Reply with quote
the info is somewhere in my notes somewhere, but if I remember correctly, the only rails that I found that fit were neon 2.0 (I think) and focus zetec engines (in the US, at least)
proud owner of a 1979 924 Sebring Edition with a 931 trans that looks horrible but somehow runs...
!tom
PostPosted: Fri Mar 30, 2012 3:29 am    Post subject: Re: Rails and injectors that work? Reply with quote
Ugh. That pre-heats the fuel, and is no better than the CIS setup!
Why don't you have the return off the fuel rail?
78 924 NA
5-lug
CorsePerVita
PostPosted: Fri Mar 30, 2012 3:19 pm    Post subject: Reply with quote
I Have a us model zetec rail off of a ford zx2 2.0L and it doesn't fit. Also, brackets I can do, that should be easy. I'm more or less worried about whether or not the rail will work with my system and fit on where it needs to be.
I'm getting mixed signals here. I've been going through everything I've been reading up. I am told that the way you describe is fine and the way I'm doing it is fine. Then there are people who are telling me the way you describe is worse and people who tell me my way is worse.
Pros and cons please, could someone explain? I can't seem to find any good relevant data on the pros and cons of each.
- 1999 Ducati 900SS
PostPosted: Fri Mar 30, 2012 4:54 pm    Post subject: Reply with quote
Seems like there isn't a way to avoid heat transfer to the fuel/rail as it sits so close to the head.
Sitting on top of intake away from the exhaust helps, as does having the fuel lines on the driver's side.
Think of the number of production vehicles that implement the fuel system in this way.
I think you'll be fine the way you've planned it. Just find the rail that fits your needs and plumb it in.
Raceboy
PostPosted: Fri Mar 30, 2012 7:17 pm    Post subject: Reply with quote
The cars that use returnless fuel rail have usually plastic intake manifolds and better venting under the hood plus lower engine temps thanks to better efficiency.
I would never consider returnless fuel rail on 924 as it is far less reliable and heats fuel unnecessarily. Fuel is heated anyway by the pump which uses fuel as coolant but you don't want the fuel to be heated more.
For example, 996 Turbos (and newer) have fuel cooling circuit through aircon system which avoids fuel vapourization in the fuel system.
I've struggled with vapourization on 924 before on hot summer days at the track (around 10 years ago) and you wan't to do anything to avoid it.
'83 924 2.6 16v Turbo, 470hp
'67 911 2.4S hotrod
'90 944 S2 Cabriolet
'78 924 Carrera GT replica
'84 928 S, sold
'91 944 S2, sold
'82 924S/931 "Gulf", sold
'84 924, turbocharged, sold.
PostPosted: Fri Mar 30, 2012 10:23 pm    Post subject: Reply with quote
I don't understand why you say the Zetec rail won't fit. According to my research, the Zetec motor has 95mm on-center injector spacing, which is identical to the injector spacing on the 924. As Stefan indicated, both the Zetec and SRT-4 fuel rails should work, as well as the 4G63/4G64 Mitsubishi variants that had 95mm on-center injector spacing.
The OBX rail for the Zetec that I PM'd you about and that Stefan linked to above seems to be the closest off-the-shelf solution because it doesn't have any funky brackets or mounting bosses to deal with. Simply unbolt the little brackets that are on it, and fab up your own to pick up the studs on the head/intake interface.
I am very seriously considering getting one of the OBX rails myself and developing a mass-reproducable bracket setup that would make it essentially bolt-on for the 924/931. Unfortunately, the supplier I was working with for my custom-developed rail is preoccupied with legal battles (trying to get pre-bankruptcy Chrysler to pay their bills), so I'm exploring the OBX route as a quicker path to a solution.
PostPosted: Fri Mar 30, 2012 11:19 pm    Post subject: Reply with quote
Regarding the heat issues... for the fuel, I've noticed our fuel tank itself gets pretty hot from the exhaust and trans on-track. Yes, the exhaust does go out the back of the car per the stock routing - though no neat shields still in there.
As for fuel rail - presumably the biggest issue to address would be conducted heat. Easy to wrap, but the mounts can still conduct heat. Aluminum mounts would thus be worst for this; plastic or similar less-conductive material would be nicer, but perhaps inadequately robust.
So, what metal (or similar material?) could we use for mounting with the lowest heat conductivity? I don't know that I'd feel comfortable testing some composite mounts - not sure I'm good enough to make those yet...
CorsePerVita
PostPosted: Fri Mar 30, 2012 11:48 pm    Post subject: Reply with quote
The rail and injectors themselves fit fine. What doesn't is bolting it down. There is an arm for the fuel hose on the rail I have off of it and it actually hits the valve cover and pushes it forward.
The thing is, the zetec engine for the focus and the escort zx2 are different, also, the zetec in 1998 was different than in 1999. So I'm assuming mine must be the wrong year, either way, it doesn't fit. It won't bolt down and sit flush with it because it runs into the valve cover. I can try and get a pic.
- 1999 Ducati 900SS
CorsePerVita
PostPosted: Fri Mar 30, 2012 11:57 pm    Post subject: Reply with quote
So you're saying heat is the issue at hand?
- 1999 Ducati 900SS
PostPosted: Sat Mar 31, 2012 12:20 am    Post subject: Reply with quote
So the OBX rail should work just fine. It's a simple log, and the brackets unbolt. I can't see any issue with making it work for your intended use.
CorsePerVita
PostPosted: Sat Mar 31, 2012 12:39 am    Post subject: Reply with quote
I guess I'll go ahead and order one then.
- 1999 Ducati 900SS
PostPosted: Sat Mar 31, 2012 12:41 am    Post subject: Reply with quote
Make sure you check their return policy.
WEASEL149
PostPosted: Thu Apr 05, 2012 3:22 am    Post subject: Reply with quote
While I had the chance, I measured my father's injector spacing on his Mercedes CLK230 Kompressor - 96mm between injector centres, so looks as though that would work.
Only one inlet on it though, so anyone using it would probably need to add a return fitting to it.
1979 UK 932
