Haynes manual on testing control pressure
doug60
PostPosted: Fri Feb 03, 2012 4:37 am    Post subject: Haynes manual on testing control pressure Reply with quote
I'm a bit confused on what i have read in the haynes manual on testing control pressure when the engine is hot, the WUR ( control pressure reg)
will now be closed for this test, so surely it should give you a control pressure reading of 65 to 75psi not what they state 49 to 67 psi surely it is just the same test as for system pressure ( page 77 ) ?? The car is a 924 1984.
Thanks for any info
PostPosted: Fri Feb 03, 2012 4:59 am    Post subject: Reply with quote
From ideola's "How to connect & operate the Hoffman CIS Test Kit" thread in the How-To forum;
Probst book via ideola wrote:
...typical specification of between 3.4 and 3.8 bar (49-55 psi)
From the copy of the factory manual I have;
Control pressure "warm" = 3.4 to 3.8 bar (~49 to 55psi)
bruce76-924
PostPosted: Fri Feb 03, 2012 5:06 am    Post subject: Reply with quote
Hi,
System and control pressure are 2 different things, do not confuse them. Remember that they are tested differently. The control pressure regulator ( warm up regulator) never fully closes. What are the problems with the car?
Bruce.
1976 924 LHD, full cage, semi tube chassis, 951 brakes, lightweight 951 body panels.
1.8t engine conversion with Holset turbo and 6 speed Audi gearbox.
doug60
PostPosted: Sat Feb 04, 2012 4:11 am    Post subject: reply Reply with quote
[quote="bruce76-924"]Hi,
Bruce.[/quote]
Hi Bruce, Thanks for the reply. I thought that the WUR completely closed when the car was warmed up, i get it now !! The car is jerky when i first start off, and very slightly jerky in the 2000-3000 rpm band after that all is fine. the tickover fine etc
Thanks DB
ptheskil
PostPosted: Sat Feb 04, 2012 8:56 pm    Post subject: Reply with quote
I have absolutely no evidence for this statement whatsoever (!) but I suspect that many (the majority) of running problems with older K-jetronic systems are due to the WUR? It seems to be susceptible to deterioration/blocking. I suspect as well that many POs have tinkered with the idle mixture when warm to get the engine running sort of OK leading to poor (lean) running when cold and lean mixture at the higher air flows.
The only way to put this right is to check/set system and control pressures hot and cold before you adjust anything else. Once you have put that right then you will probably have to undo previous adjustments. A proper fuel pressure test is the only way to go.
1981 931 series2 Euro spec
bruce76-924
PostPosted: Sat Feb 04, 2012 10:09 pm    Post subject: Reply with quote
It is also susceptible to being fiddled with in the ignorance that you can adjust it to get more power. It can be adjusted but you need to know the pressures it is then set at. Many control pressure regulators ( WUR) have been messed about with by people who don't know what they are doing and just following "Internet experts"! Beg, borrow, steal or even buy the correct gauge and get the system set to the factory specs. Don't forget the basics though, plugs, leads, cap, rotor and filters.
Bruce.
dpw928
PostPosted: Sun Feb 05, 2012 12:36 am    Post subject: Reply with quote
Bruce.
Agreed. The warm up regulator adjusts control pressure based upon the ambient temp through the bimetal plate that changes the valve adjustment. If the control pressure is correct at one temp, it should be correct at all temps unless the laws of physics have changed. Since the engine seems to be running correctly when warm, other areas as suggested by Bruce should be checked. Also the AAV could cause poor cold running if it is stuck closed.
Dennis
81 931 5 sp
78 928 5 sp Silver
78 928 AT Euro Black
PostPosted: Sun Feb 05, 2012 3:14 am    Post subject: Reply with quote
Disagree.
WUR plays a role, so to do dirt (from cheap fuel without sufficient detergent) and vaccuum leaks.
