Julian
Posted: Fri Dec 09, 2011 9:45 pm Post subject: Air regulator |
Where is, or what fuse, covers the lead to the Aux. Air Regulator? Should that lead have 12 volts during all the engine opperating time?
Thanks |
Joined: 29 Jul 2001 Posts: 9073 Location: Royal Oak, MI, USA
Posted: Sat Dec 10, 2011 12:21 am Post subject: |
Yes, it should; not certain as you didn't post your year and model, but usually that's powered off the same fuse as the fuel pump, and also shares the power connection with the thermo-time switch/cold start valve and the control pressure regulator. _________________ Vaughan Scott
Julian
Posted: Sat Dec 10, 2011 12:35 am Post subject: |
| Thanks, it's a 78 924. I traced it to the cold start. If they are both on the same line would explain some starting issues, Other than the fuel pump runs correctly. I don't see where there have been any extra wires run to the fuel pump. Only fuse blown is to some interior lights. Could that be on a relay? |
Posted: Sat Dec 10, 2011 3:26 am Post subject: |
More likely broken wiring. _________________ Vaughan Scott
