joecitizennn
Posted: Fri Nov 25, 2011 12:08 pm Post subject: goodbye 2.5... hello winter project |
I had always planned on starting a v8 hybrid project but not so soon. I was at the gas pump several days ago and noticed that my normally aspirated carrera body 924s has been getting a consistant 20mpg. It does this every winter, dropping from about 23mpg in the summer months, to worse mileage on the winter grade fuel. Sometimes it falls to 19. It is irritating to get such mileage from a 150hp 4 cyl. This led me to a craigslist find that was too good of a deal to pass up, so now long story short this is sitting in my garage.
It is a 1997 aluminum head chevy lt1 with 85k miles. with aluminum heads it weighs about 80 lbs over the newer ls1. Stock horsepower I believe to be around 300 but I am not a chevy man and am still doing alot of reading and learning.
I will be keeping the transaxle system, but there will be a very solid running 2.5 for sale in the near future.
Black Forest racing installed a lt1 383 stroker with somewhere near 500 RWHP in a 951 and claimed that the transaxle took season after season on the race track without a problem of any kind. Unmodified lt1s have been getting around 30mpg on the highway, so I am hopeful that this project will produce a cheaper to run, more reliable and more powerful car. _________________ 87 924s
88 924SE gone
447 hp cgt clone
87 924S gone
84 944 sold
83 944 sold
89 turbo S LSD, ABS etc
86 951 white rocket
85 944 sport everything.
84 944 sold.
87 944 sold
Last edited by joecitizennn on Fri Nov 25, 2011 12:56 pm; edited 3 times in total |
Sigurd
Joined: 25 Sep 2010 Posts: 44 Location: British Columbia , Canada
Posted: Fri Nov 25, 2011 12:45 pm Post subject: |
Nice project! Looking forward to seeing pics of the progress. The weight distribution shouldn't be to out of whack either, about 100lbs more in the front, right? _________________ '77 924 |
joecitizennn
Posted: Fri Nov 25, 2011 1:00 pm Post subject: |
| Sigurd wrote: | | Nice project! Looking forward to seeing pics of the progress. The weight distribution shouldn't be to out of whack either, about 100lbs more in the front, right? |
I am thinking closer to 150, but like I said I have just started my research. If it does prove to be heavier I can always swap my fenders and hood for fiberglass. I dont think a balanced car will be hard to come up with. I am going to drop the AC and the mechanical headlights for sure, that should count for something. _________________ 87 924s
88 924SE gone
447 hp cgt clone
87 924S gone
84 944 sold
83 944 sold
86 951 white rocket
84 944 sold.
87 944 sold |
Posted: Fri Nov 25, 2011 5:08 pm Post subject: |
Sorry to burst your bubble, but unless you install a OD assembly into the TT (requiring cutting it all up), or you install the matching transmission and drivetrain you will never see better fuel economy.
If you convert to a programmable engine system you can do a lean burn and get WAY better fuel economy.
I did this with an 86.5 928S engine and went from 20-22mpg to 35mpg. _________________ 3 928s, |
Posted: Fri Nov 25, 2011 5:58 pm Post subject: |
I dunno, the 951 trans has a pretty high 5th/Final.
Joe, you using Renegade parts? _________________ Toofah King Bad
joecitizennn
Posted: Fri Nov 25, 2011 11:49 pm Post subject: |
I have a lsd tranny with the super tall 5th gear from the early 944 that I am going to use. As far as adapting it in, I will probably use a c5 bellhousing and make my own adapter plate. Even if it gets the same mileage, I cant argue with double the horsepower. _________________ 87 924s
88 924SE gone
447 hp cgt clone
87 924S gone
84 944 sold
83 944 sold
86 951 white rocket
84 944 sold.
87 944 sold |
bnoon
Joined: 12 Oct 2009 Posts: 607 Location: West Des Moines, IA USA
Posted: Sat Nov 26, 2011 2:55 am Post subject: |
There are some nice tuning options for the LT1 engines out there. You will have no problem getting better MPG out of it in stock or modified configurations. I had a '93 TA with 4:10 gears and 400 horse to the wheels and got 29 MPG highway out of it. You will no doubt have a better final drive than that car did with your 5 speed. _________________ '80 924 Turbo - SOLD!
Porscheless  |
Posted: Sat Nov 26, 2011 4:20 am Post subject: |
Nice. Good choice on parts. _________________ 1979 porsche 924 Na
Have u ever driven a turbo. |
Sigurd
Posted: Sat Nov 26, 2011 4:58 am Post subject: |
| joecitizennn wrote: | | Sigurd wrote: | | Nice project! Looking forward to seeing pics of the progress. The weight distribution shouldn't be to out of whack either, about 100lbs more in the front, right? |
I am thinking closer to 150, but like I said I have just started my research. If it does prove to be heavier I can always swap my fenders and hood for fiberglass. I dont think a balanced car will be hard to come up with. I am going to drop the AC and the mechanical headlights for sure, that should count for something. |
Yes, you can definately shed a few pounds by going to figerglass in the front. That's awsome, trading weight for power . _________________ '77 924 |
Posted: Sat Nov 26, 2011 8:29 am Post subject: |
Regarding weight, I don't know how the 2.0L compares to the 924S, but the 931 DIN curb weight was just over 150 lbs. heavier than the normally aspirated 924, and given the lighter gearbox, it's a good bet that most of it was due to the added components in the engine bay. I don't think 100 or so pounds will be too terribly bad... _________________ erstwhile owner of just about every 924 variant ever made |
