A little work on the 924 Carrera GT.
MikeCGT
PostPosted: Thu Jun 23, 2011 9:43 pm    Post subject: A little work on the 924 Carrera GT. Reply with quote
Thought I'd share some recent work on the 924 Carrera GT.
I wanted to do a few repairs and a little detailing to the paintwork, it was mainly the polyurethane plastic parts that were suffering the most.
The rear arches had the common problem of the stud heads having blown the surface and blistered the poly, and the inter-cooler scoop had some
stress fractures as did the rear bumper.
The front off-side wing had a small badly done repair under the decal so I thought I'd take the opportunity to do that as well. That meant replacing
the decal and after no luck in sourcing a NOS pair for front and rear, decided instead of putting on aftermarket version's I'd have them done in paint!
After the restoration and paintwork to the rear arches it was the refitting I was dreading, the edging strip is no longer available for both sides so
carefully cleaned up the existing pair and section by section re-fitted them by using a little glue to hold them in place on the arch. Then as the arch
goes on with liberal amounts of copperslip on the studs, you can adjust the edging strip up and down as you tighten the stainless nuts with their
rubber washers to get the uniform finish all the way along the edge of the arch. A painstaking process but worth it in the end. I've included a picture
of the rear quarter with the arch off, to give an idea of how much is cut off the panel for wheel clearance.
Really pleased with the way it's all worked out, especially the edging strip. The painted decals while obviously not original look fantastic and the
original paint on the rear quarters with it's Volkswagen paintshop orange peel even adds a certain character! Hope you like it.
cheers, Mike
1981 924 Carrera GT 0441
macBdog
PostPosted: Thu Jun 23, 2011 9:49 pm    Post subject: Reply with quote
Absolutley stunning. Obvious commitement to quality there.
Do you have a few more pics of how the studs lay in the fenders? I'd like to do mine in the same way or as close as possible.
1979 931 with a 350 chev
1973 911E with EFI
p-talk wrote:
I'm still convinced the word 'Porsche' makes people crazy in all kinds of ways
PostPosted: Fri Jun 24, 2011 12:28 am    Post subject: Reply with quote
Beautiful, thanks for the pics.
PostPosted: Fri Jun 24, 2011 12:47 am    Post subject: Reply with quote
1+
MikeCGT
PostPosted: Fri Jun 24, 2011 1:13 am    Post subject: Reply with quote
Sorry, but didn't do any more detailed shots, are you thinking about doing the same repair to an original or fabrication into repro fenders?
cheers, Mike
PostPosted: Fri Jun 24, 2011 5:04 am    Post subject: Reply with quote
Aahhh I see the side skirts run in under the rear fenders a bit.
Nice pics...I know of a good vinyl maker I need to talk to him &
see what he can do Im sure I could get them super cheap.
macBdog
PostPosted: Fri Jun 24, 2011 11:09 am    Post subject: Reply with quote
Fabrication into repro fenders. The install guides for rear fenders that I've seen show rebated/countersunk holes for flat rivets with filler over the top but this seems a bit shadetree for me compared to those studs you have in yours.
1973 911E with EFI
porscheboy79
PostPosted: Sat Jun 25, 2011 8:22 am    Post subject: Reply with quote
Great Pics
The rubber piping between guard and flare is available in australia.
We use it on restorations of the A9X torana. It comes in pre cut lengths or off the roll.
"After the restoration and paintwork to the rear arches it was the refitting I was dreading, the edging strip is no longer available for both sides so
of the rear quarter with the arch off, to give an idea of how much is cut off the panel for wheel clearance. "
[/img]
MikeCGT
PostPosted: Thu Jun 30, 2011 3:38 am    Post subject: Reply with quote
Sorry for not coming back to you sooner. This is the system that Porsche use to fix on the arch extensions.
You would need to make or find a small M6 stud on a small plate, perhaps a little smaller than this one, as this is the part to fix the rubber
to the rear bumper, but the same principle. Then bond that flush into your arch extension to fit through the holes in the panel you then make
to line up, a dozen each side. They are secured on the inside by a rubber washer, mocked up here, with a stainless washer and lock nut.
The positioning for them are two centrally accessible from behind the arch panel, then 5 in the trunk space and 5 in the space between the
panels accessible though the grill space in the lower 'b' post.
Also as far as finding the plastic edging trim, the original is color coded to the car, it came in black, red and silver depending on the car color.
Hope that's of some help and good luck with it all.
cheers, Mike
Ole Petter
PostPosted: Wed Jul 06, 2011 5:13 am    Post subject: Reply with quote
Brilliant Mike!
My car has the same rusty bolts on the rear right hand side. At some time I will have to do a similar repair.
924-obama
PostPosted: Fri Jul 08, 2011 6:41 pm    Post subject: Reply with quote
rock ' n roll !!!!!
PostPosted: Sat Jul 09, 2011 12:55 am    Post subject: Reply with quote
So how did you go about getting the lettering masked up to paint ???
very nice looking car though Mike
MikeCGT
PostPosted: Sat Jul 09, 2011 10:49 am    Post subject: Reply with quote
You paint the panel red first, then lay on the mask you have made from the scanned image of the best of the aftermarket decals.
Paint the black coat, then peel of the mask revealing the red lettering. Flat and clear coat to finish.
Hope that helps, Mike
cheers, Mike
