TJC
Joined: 04 Apr 2010 Posts: 828 Location: Northwestern-ish Arizona, USA
Posted: Mon Feb 14, 2011 3:01 pm Post subject: Bellhousing Interchangeabilty? |
Simply stated, what is the difference between an early 924 NA, 924 Turbo and 924S/944 Bellhousing? _________________ '95 BMW 318i/5 ..."Pearl"
'04 BMW X3..."Xander"
Still on the Prowl!
www.ttrs1.com |
Posted: Mon Feb 14, 2011 4:23 pm Post subject: |
924 and 931 units bolt up to 2.0 block. 931 unit is designed for hydraulic clutch. Both have stoopid number and variety of bolts!
2.5 unit bolts up to 2.5 block with four tidy bolts, accomodates identical clutch actuation parts as 931 unit (slave cyl, clutch fork, shaft, guide tube).
I'm sure there's more. . . _________________ Toofah King Bad
TJC
Posted: Tue Feb 15, 2011 2:36 am Post subject: |
Thank's Rasta, that answers my question! _________________ '95 BMW 318i/5 ..."Pearl"
Still on the Prowl!
www.ttrs1.com |
stv951
Posted: Sun Jun 05, 2011 3:03 am Post subject: |
I believe that 931 belhousing bolts on to the 2,5/3,0 944 engines.
Obviously you'll need to use the flywheel and clutch from the newer engine _________________ Steve
931 81 177 bhp White
931 81 0 bhp engineless Platinum
924S 86 stripped with cage for Track days Red
944 83 Auto Blk
924 84 project 924 CGTS with 951 running gear
944 S2 90 Convertible 3xBlack
951S 91 Vitesse stg 3 350 bhp |
Posted: Sun Jun 05, 2011 5:05 am Post subject: |
| stv951 wrote: | I believe that 931 belhousing bolts on to the 2,5/3,0 944 engines.
Obviously you'll need to use the flywheel and clutch from the newer engine |
Wrong. The engine's are completely different and the 931/924 blocks are the same (shares bellhousing pattern with the Audi 5-cylinder motors).
The bellhousings can all be bolted to any of the torque tubes available as they share the same 4-bolt pattern. _________________ Stefan
the_mad_electrician
Posted: Tue Jun 21, 2011 8:23 pm Post subject: |
| fiat22turbo wrote: | Wrong. The engine's are completely different and the 931/924 blocks are the same (shares bellhousing pattern with the Audi 5-cylinder motors).
The bellhousings can all be bolted to any of the torque tubes available as they share the same 4-bolt pattern. |
| Quote: |
How new of Audi 5 cylinder engines match the pattern? |
_________________ 81 924 N/A
2004 Ranger "Edge"
2005 Mazda 6 |
