Bockscar
Joined: 16 Nov 2010 Posts: 392 Location: Sandy, Oregon
Posted: Thu Jun 02, 2011 1:55 am Post subject: Expansion tank alternatives? |
According to Pelican Parts, the radiator expansion tank is roughly $100 and needs to be sourced from Germany. That is awful steep for a silly piece of plastic that's only purpose is to hold water under pressure.
Are there any alternatives that can be used out there that I don't have to order from Germany? $100 is an injury by itself but having to order it from Germany and pay the extra costs for it just insulting. Ironically, I have all of the plumbing necessary for the darn thing, it's just that the PO apparently miss placed the original tank. _________________ Brian
'79 924 - Restoration In Progress
'81 924 Turbo w/EFI - Scrapped |
Posted: Thu Jun 02, 2011 3:02 am Post subject: |
i bougth mine from porsche themself, cheap and good looking.. _________________ 1980 924 Turbo
Posted: Thu Jun 02, 2011 3:05 am Post subject: |
You can use a 944 unit, but it will still cost you. _________________ Toofah King Bad
Posted: Thu Jun 02, 2011 4:19 am Post subject: |
I'd see if someone is parting a 931 and buy theirs (provided that it doesn't leak, heh)
The 944 unit bolts onto the top of the driver's side fenderwell (under the quarter panel and one bolt into the side of the fenderwell just ahead of the fuel filter on a 924 NA).
I don't know what is needed to adapt a 944 tank to a 931, but for my 924 NA it wasn't very difficult, just ran a couple pieces of generic heater hose from the radiator to the expansion tank.
Luckily, the 944 is more common so the tanks are a little easier to come by used. I would urge you to clean it and the radiator before using them. Mac's Radiator on Foster has done great work for me in the past.
Good luck! _________________ Stefan
Bockscar
Posted: Thu Jun 02, 2011 12:56 pm Post subject: |
Does our expansion tank have a fluid level sensor built into the top? _________________ Brian
Posted: Thu Jun 02, 2011 1:36 pm Post subject: |
Neither of the ones for the NA or the 944 did. I idont remeb seeing one for the 931. _________________ Stefan
Shurick
Joined: 15 May 2005 Posts: 524 Location: Russia, Moscow.
Posted: Tue Jun 21, 2011 12:03 am Post subject: |
| Bockscar wrote: | | Does our expansion tank have a fluid level sensor built into the top? |
According to PET the where no level sender unit in 924, 931 or 944. _________________ WBR, Shurick
'86 924S -- R.I.P.
https://www.instagram.com/ru_pacecar/ |
Bockscar
Posted: Tue Jun 21, 2011 3:08 am Post subject: |
So it turns out that the coolant expansion tank from a 1981 Scirocco fits nearly perfect on the mount. The Primary difference? The expansion tank from the Scirocco costs about $12, and the Porsche expansion tank costs about $120  _________________ Brian
Posted: Tue Jun 21, 2011 3:30 am Post subject: |
Bockscar
Posted: Tue Jun 21, 2011 2:19 pm Post subject: |
Pow!
stevekat
Joined: 19 Jan 2008 Posts: 719 Location: Los Angeles, CA
Posted: Tue Jun 21, 2011 5:40 pm Post subject: |
Nice find! _________________ "Never get out of the boat. Absolutely goddamn right. Unless you are goin' all the way."
Gone to new home: '81 924T, US version, CGT Intercooler, UTCIS-PT, Euro DITC, Greddy Trust MBC, Forged Fuchs Flat Dish 6's, Factory Recaro's. |
Posted: Wed Jun 22, 2011 1:18 am Post subject: |
Oh, snap! It's even Meyle!
So, are you close to running yet? Historics are right around the corner. _________________ Toofah King Bad
Bockscar
Posted: Wed Jun 22, 2011 1:45 am Post subject: |
You betcha it is! Volkswagen + Porsche = 1:1
Meh. I'm waiting for the fuel pressure tester/primer to arrive. Other than that though, It's pretty much ready to go. I'm sure there will be other troubleshooting issues when the engine is running though. _________________ Brian
quickr-2
Joined: 07 Nov 2008 Posts: 5 Location: Warwick, Rhode Island
Posted: Wed Jun 22, 2011 5:56 am Post subject: |
| Yes,same one I use on my 81 931. Cost about 16.00 with cap. All you have to do is replace the hoses going to it with slightly longer ones. Total cost about 20.00. Been on my car for 10,000 miles,no problems at all. Regards;Chris |
kirkvw72
Joined: 09 Apr 2014 Posts: 5 Location: Bartlett, Illinois
Posted: Sat Apr 12, 2014 11:26 am Post subject: |
Bought the Scirocco tank to replace my leaking original in my 931. The bottom hose inlet/spout is smaller than the stock one. I was wondering if people have just cinched down the larger hose, or gotten creative to size it down with a reducer, etc. _________________ 1981 931
1987 951
1987 Vanagon GL
1972 VW Beetle
1992 Miata
2013 Touareg Lux Vr6 |
