Posted: Wed Jun 01, 2011 2:52 am Post subject: Reverse gear problem? |
I swap my tranny for a spare one I have and change the clutch cable and now I can’t engage the reverse rear.
No problem engaging the other gear, 1 to 4, but every time I try to engage the reverse gear I get that
grinding sound and vibration on the shifter stick, like the gear still turning and I can’t get in.
I try starting the car in reverse with the clutch depress and release it to confirm that the reverse gear is functional.
I have no history on this tranny, I was just hoping that it would be better
then the other one that have a small leak and was sometime hard to engage in reverse.
So, what do you thing it is?
Dead synchro?
Cable adjustment?
??? _________________ 1976 924 N/A ROW SOLD
1980 931S
1981 931 Part car RIP |
gerben1986
Joined: 13 Mar 2008 Posts: 232 Location: The Netherlands
Posted: Wed Jun 01, 2011 3:38 am Post subject: |
| Maybe you need to (re)adjust the clutchcable? That is what it sounds to me. |
Posted: Wed Jun 01, 2011 5:24 am Post subject: |
So I guess that I would need to tight it up a bit?
and why it only causing me problem with the reverse gear? _________________ 1976 924 N/A ROW SOLD
1980 931S
Posted: Wed Jun 01, 2011 7:58 am Post subject: |
Could be the worn shift lever problem (if reverse in the 4-speed shift pattern is the same as in the Audi 5-speed (to the right and back)).
A how-to fix is here - http://www.924board.org/viewtopic.php?t=18424 _________________ "..it's made in Germany. You know the Germans always make good stuff."
Martijnus
Posted: Wed Jun 01, 2011 9:19 am Post subject: |
Since we're talking gearboxes... is there a synchro for the reverse gear? And first gear?
Why would there be a synchro? There's no previous gear to sync with...or am I posing a stupid question here?  _________________ "Rule: Turbo's make torque, and torque makes fun." (C. Bell)
924 "50-jahre", 1981.
MSII/extra, LPG, ITB's, 5lug.
To be turbo'ed in a while.
Posted: Wed Jun 01, 2011 10:27 am Post subject: |
Problem solved
A warm up tranny and a bit of adjustment did the trick.
Thanks to all. _________________ 1976 924 N/A ROW SOLD
1980 931S
StienbargerR
Posted: Wed Jun 01, 2011 10:32 am Post subject: |
No reverse syncro. _________________ 1978 924 NA
