play on new rear wheel bearing
jessy1984
PostPosted: Thu May 26, 2011 2:37 am    Post subject: play on new rear wheel bearing Reply with quote
hi i have some play on my new rear wheel bearings i have removed it again checked everything 3 times everything is sitting like it should be
these are bearings from skf a real good brand porsche uses these also
torqued to 300nm even a bit more
now i saw more posts about this but no solution
dous anyone know why this is ?
last time i changed some these bearings was with an NA924 and there was no play
PostPosted: Fri May 27, 2011 4:43 am    Post subject: Reply with quote
Believe one or more spacers back there can cause excessive play due to wear.
-And pretty sure the main culprit appears here as "6" -
jessy1984
PostPosted: Fri May 27, 2011 7:53 pm    Post subject: Reply with quote
thanks for the responce put this can not be the problem the rings will always be fastend by the central nut even iff its up to 1mm to short
but i found the problem today
the outer wheel bearing from FAG (you can always see the brand on the bearing itself not the package)
i have chaged the inner ring from that bearing bak to the old one and the play is gone
