Squealing Dump Valve
Clbmkr1
PostPosted: Thu May 12, 2011 1:14 am    Post subject: Squealing Dump Valve Reply with quote
My 1980 931 has a loud squealing sound when the dump valve releases pressure; Normal?
Jim Baldwin
1980 931
2013 Lincoln MKZ
2013 Ford Escape
PostPosted: Thu May 12, 2011 1:24 am    Post subject: Reply with quote
Nope. Seems more likely to be coming from somewhere else. . .you sure it's the recirc valve?
PostPosted: Thu May 12, 2011 1:33 am    Post subject: Reply with quote
If it is from the recirc valve, maybe it stucks halfway. I had a problem where the old gasket in the valve just melted and smered along the walls of the valve piston. Made the valve stuck open, no sound though but no boost either. Solved by buying a new gasket from porsche.
Clbmkr1
PostPosted: Thu May 12, 2011 2:10 am    Post subject: Reply with quote
It only squeals toward the top of the boost range, then stops as soon as you let off. It just started over the weekend.
Jim Baldwin
1980 931
2013 Lincoln MKZ
2013 Ford Escape
PostPosted: Fri May 27, 2011 4:51 am    Post subject: Reply with quote
Any chance it's a loose/leaky wastegate control line?
They're known to make a high pitched sound..
Clbmkr1
PostPosted: Mon May 30, 2011 11:09 pm    Post subject: Reply with quote
This turned out to be a loose connect at the bottom junction of the boost tube. Tightened the two bolts, now its fine.
Thanks,
Jim Baldwin
1980 931
2013 Lincoln MKZ
2013 Ford Escape
