joecitizennn
Posted: Tue Apr 12, 2011 1:39 pm Post subject: The perfect oil. |
So many people ask the question. So many different answers. This is my vote for all around use.
 _________________ 87 924s
88 924SE gone
447 hp cgt clone
87 924S gone
84 944 sold
83 944 sold
89 turbo S LSD, ABS etc
86 951 white rocket
85 944 sport everything.
84 944 sold.
87 944 sold |
Posted: Tue Apr 12, 2011 3:52 pm Post subject: |
El Chato
Posted: Tue Apr 12, 2011 5:04 pm Post subject: |
I had to order mine, no one in El Paso carries it. Still have it on the side for the engine rebuild. _________________ 1979 924 N/A, Snail Shell
1980 924 N/A
1976 924 N/A
It may be that your whole purpose in life is simply to serve as a warning to others.
Today's weirdness is tomorrow's reason why. |
joecitizennn
Posted: Wed Apr 13, 2011 8:50 am Post subject: |
| Rasta Monsta wrote: |  |
That should coke your bearings. _________________ 87 924s
88 924SE gone
447 hp cgt clone
87 924S gone
84 944 sold
83 944 sold
86 951 white rocket
84 944 sold.
87 944 sold |
agfisher
Joined: 09 May 2007 Posts: 484 Location: West Hartford, CT
Posted: Thu Apr 14, 2011 4:29 am Post subject: |
Just make sure it's cold-pressed!  _________________ 1977 924 N/A Martini Edition |
v8carreragts
Posted: Thu Apr 14, 2011 6:57 am Post subject: |
I use AmsOil as well. I've been using it since 1980. _________________ 84 944--924 Carrera GTS clone w/520HP Chevy 302 V8--RUNNING!
2015 AUDI Q7
2013 Dodge Charger R/T AWD HEMI
2013 Chevy Cruze |
Jakkq
Joined: 29 Sep 2008 Posts: 810 Location: Omaha, Nebraska
joecitizennn
Posted: Sun May 08, 2011 3:20 am Post subject: |
I would not suggest using 0w40 oil in our cars. Can't really speak for the audi 2.0 engine as that is not my area. Running 10 30 to 20 50 depending on the conditions seems appropriate for the 2.5. The 10 40 pictured covers a broad range of operating temperatures. This is not an oil you drain every 3 months, you can run this stuff for a year if you wish depending on operating conditions. That is why i picked a weight that will work in a broad range of temperatures. Some of my cars only get 1000 miles a year put on them and it just makes no sense to dump a lot of oil. If I was racing I would go with a heavier weight, if I was living in alaska I would go lighter. _________________ 87 924s
88 924SE gone
447 hp cgt clone
87 924S gone
84 944 sold
83 944 sold
86 951 white rocket
84 944 sold.
87 944 sold |
Posted: Sun May 08, 2011 5:02 am Post subject: |
Lower cold viscosity number is always better for the engine since you will have a lubricant which flows much better at cold starts, even on summer days. But it often costs more money and if you dont have so much of it spend it else were and buy a cheaper 5w or 10w40 instead. _________________ 1980 924 Turbo
