neophite
Posted: Tue Feb 01, 2011 12:00 am Post subject: Misfiring |
| Please help with my misfiring problem. It will miss at any speed but particularly when I let off the clutch after upshifting. I have also noticed that at idle the rpms will sometimes drop considerably and then come back up. I have replaced the plugs, fuel filter, o2 sensor,and dme relay. My plug wires, distributor cap, and rotor are not that old. Please tell me where I need to go from here. As always, your help is greatly appreciated. |
Haven
Posted: Tue Feb 01, 2011 7:57 am Post subject: |
I am by no means an expert on these engines, as I just bought a 924S recenty myself.
But... it sounds like it could possibly be a vacuum leak problem or maybe the reference mark sensor, which basically acts like a camshaft position sensor.
If your reference sensor is bad, then your engine doesn't know when to fire and it can cause the symptoms you described.
I'm sure someone with more knowledge will chime in before long.
Good luck with it! _________________ 1987 Porsche 924S Auto |
Posted: Tue Feb 01, 2011 8:05 am Post subject: |
You might check the AFM for wear on the contact "tracks." Also, these things are getting to the age where a vacuum refresh is becoming mandatory (all lines, plus AOS seals). See 944Online for a good kit for this project.
I would also recommend refreshing the feed, return, and "jumper" fuel lines (before the car catches on fire and burns to the ground). See RennBay for these items.
Neither of the above are cheap procedures, but it's a Porsche!
Good luck! _________________ Toofah King Bad
neophite
Posted: Thu Feb 03, 2011 1:29 am Post subject: |
| Thanks guys, now I have an idea of where to start. I will replace and test when my budget allows it. Again, Thanks |
masterdave
Posted: Thu Feb 03, 2011 5:36 am Post subject: |
| i had a similar problem and it was the fuel pump ground, the power was getting to it fine but the pump ground was so dirty it was not working properly and the pump was running at like half power. it is very simple to check fuel flow,first disconnect the battery, simply remove the nut on the head of the fuel rail, connect a piece of rubber hose to it, run it to a measuring cup, jump i think terminals 80 and 32b, on the DME relay. If you dont have the Haynes manual GET ONE, they are a huge help. then reconnect the battery this will kick the pump on and fuel will flow in to the measuring cup, i want to say its 500ml every 30sec or min, but the haynes manual will tell you what value you should be getting. If you are not getting proper flow you may have either a bad pump or bad pump ground. I would also advise checking the injectors, they ban be checked with a simple multi meter, again the haynes value will have the right measurement. I happen to be away at school and dont have my manual other wise i would look up all these values. if you have access to an oscilloscope you can check the out put of the DME to the injectors, it should be a square wave at 12 volts. |
Posted: Thu Feb 03, 2011 12:43 pm Post subject: |
Check your engine grounds. _________________ White 87 924S "Ghost"
neophite
Posted: Fri Feb 04, 2011 6:45 am Post subject: |
| I will do the tests. Thanks |
neophite
Posted: Tue Apr 05, 2011 2:41 am Post subject: |
I am ready to drive this car off a cliff. As suggested, I replaced the engine grounds (which I assume are the 2 negative battery cables), cleaned what I think is the fuel pump ground (really could not tell but it was a brown wire from the pump that attached and a female connector),
checked fuel out put, replaced plug wires and rotor. Still cuts out but not as much. I have noticed it misfires a lot worse on cold or rainey days which makes me believe it is electrical. Suggestions PLEASE! |
Posted: Tue Apr 05, 2011 2:43 am Post subject: |
There is a cluster of grounds at the back of the intake manifold that should be disassembled, cleaned, and reassembled with antioxidant. _________________ Toofah King Bad
headstrong2740
Posted: Tue Apr 05, 2011 2:48 am Post subject: |
| Hey was i not mistaken... but is there not a coil on the passanger fender well that runs to the center of the distributor cap... Could be worth having it tested and see if it is within spec. I know autozone can test most of these. |
neophite
Posted: Tue Apr 05, 2011 2:58 am Post subject: |
Thanks for the quick replies. I will look for the cluster of grounds but don't recall seeing them. It may well be the case that I don't know what I am looking for. I will also have the coil tested.
Thanks |
Posted: Tue Apr 05, 2011 3:15 am Post subject: |
Don't recall exactly, but it may be in a lovely spot under the heater control valve. _________________ Toofah King Bad
Posted: Tue Apr 05, 2011 12:21 pm Post subject: |
Yes under the heater valve on the bell housing near the reference mark sensors. _________________ White 87 924S "Ghost"
Posted: Tue Apr 05, 2011 12:26 pm Post subject: |
neophite
Posted: Tue Apr 05, 2011 10:59 pm Post subject: |
| Many thanks for the photos. Now I will have to figure out how to get to them this weekend. |
