From 7.5 to 8.5?
Shurick
Guest
PostPosted: Thu Oct 17, 2002 6:44 am    Post subject: Reply with quote
Actually I'm rebuilding a 31/01 engine. What do I need to upgrade to 8.5:1 c.r., like 31/03? I think, that the higher pistons will resolve the problem. But there is one more problem -- the ignition. 31/01 std ignition can led to the detonation.
In my plans are the 951 or Audi 200 intercooler installation and boost pressule up to 1 bar. It must produce nearly the 250 bhp, but how to kill the detonation?
[ This Message was edited by: Shurick on 2002-10-17 06:47 ]
Zuffen
PostPosted: Thu Oct 17, 2002 7:07 am    Post subject: Reply with quote
Do a search on the net for the Volvo APC system, there is a site which explains how to retrofit a knock unit into a none knock car. It might help.
Also water injection and water cooling of the intercooler will help keep cahrge air temps down.
But unless you really are going to be boosting higher than 1 bar, even at 8.5:1 your fine with an intercooler
Bob Dodd - 924turbo@cox.net
I have Way too many cars, parts for the 931,944 and 951
924 turbo
Guest
PostPosted: Thu Oct 17, 2002 8:09 pm    Post subject: Reply with quote
Just out of curiosity, what "problem" are you trying to solve by switching from 7.5 to 8.5 pistons?
Shurick
Guest
PostPosted: Fri Oct 18, 2002 3:24 am    Post subject: Reply with quote
The car looks dead on low RPM...
924 turbo
Guest
PostPosted: Fri Oct 18, 2002 5:51 am    Post subject: Reply with quote
Ok, you're right, that will solve the problem!
