taking apart throttle housing?
Duncan
PostPosted: Mon Mar 14, 2011 9:53 pm    Post subject: taking apart throttle housing? Reply with quote
Is it possible, smart, advisable to take apart the throttle housing, for example to get the exterior bead blasted?
I can remove the one nut on the butterfly axis, but the rest remains frozen together.
Thanks and cheers,
Duncan
1983 NA Alpineweiss since 2001
Peugeot 205 Generation
PostPosted: Mon Mar 14, 2011 10:15 pm    Post subject: Reply with quote
Yes, it's possible, and not that big of a deal. I had to do some disassembly and re-assembly when I converted my late NA throttle body over to the big bore Audi unit. I've also torn down and rebuilt a couple of the S2 931 units.
I would recommend taking good photos of everything before you disassemble it, however, so that you have a good reference for putting it back together, especially with respect to how the springs and levers are supposed to be arranged.
Duncan
PostPosted: Tue Mar 15, 2011 4:06 am    Post subject: Reply with quote
How did you remove the linkage from the axis and how did you remove the actual butterflies from the axis?
The linkage is seriously stuck. I used moderate force without success on a RHD unit I bought erroneously, but for my own I have to be more careful.
I am very curious...
Duncan
