GT Carrera Wheels
jbwheele
PostPosted: Wed Mar 09, 2011 6:39 pm    Post subject: GT Carrera Wheels Reply with quote
Could someone explain where the Offset is measured from on the rims? I want to get some wider rears like the standard GT fuchs but not break the bank
Joe
82 932 Stripped bare full rebuild
80 932 GT Lookalike Engine S2 swap
PostPosted: Wed Mar 09, 2011 11:59 pm    Post subject: Reply with quote
http://www.rimsntires.com/specs.jsp
PostPosted: Thu Mar 10, 2011 3:04 am    Post subject: Reply with quote
Size- Part No.- Tyre - Shared with -
Fuchs Front - 7Jx15 ET23 -911 361 020 41 - 215/60 VR15 - 911 SC
Fuchs Front (option) - 7Jx16 ET23 - 911 362 115 00 - 205/55 VR16 - 911 SC
Fuchs Rear - 8Jx16 ET23 - 911 362 117 00- 225/50 VR16 - 930
jbwheele
PostPosted: Thu Mar 10, 2011 3:52 pm    Post subject: Ah HA! Reply with quote
So the offset is measured from the centreline of the wheel to where it actually fits up to the hub, sweet so the bigger the positive offset the further out the mounting and the smaller the "Dish" of the rim.
Inversly the smaller or even negative offset has a "Deeper" Dish
RrrrriiiiiighhhhhT !
So for a 924 Carrera or / 944 Early models the (23 ET) is 23.. External ?
on front and so to "Fill the Rears well 13 ET or less would look much better than using 23s on the Rear? or for a really Ultra wide flareed car a negatively offset wheel would provide a Deep Dish.
Joe
Nein37
PostPosted: Fri Mar 11, 2011 12:25 am    Post subject: Reply with quote
The 911 8X16s have a 10.6ET
The 951 8X16 have the 23.3ET
The Carrera GT usually came with the optional 7X16 and 8X16 911 offset wheels.
The ultimate setup to fill the wheel wells would be 911 offset 8X16s in the front and the 9X16s with additional 5mm spacers in the rear.
1981 931 CGT replica, OEM CGT intercooler, .8 BAR WG spring, GTS Headlights, Innovative Wide band A/F, A/C delete, 16" Fuchs, Weltmeister 200lb lowering springs, Bilstein HDs front, Koni Sport rears.
