Posted: Sun Nov 07, 2010 4:28 pm Post subject: |
Yea the scoop looks pretty aggressive. _________________ 1979 porsche 924 Na
Have u ever driven a turbo. |
the_mad_electrician
Posted: Thu Dec 02, 2010 10:46 am Post subject: |
I was thinking about using this method to make a box for ram air for my Webers. Have a box with a tube near the front with a filter kinda like a cold air intake. _________________ 81 924 N/A
2004 Ranger "Edge"
2005 Mazda 6 |
Posted: Tue Jan 11, 2011 1:41 am Post subject: |
Except go to a auto-body paint supply house.. and look for a tube of stuff called easy sand ...its easy to work with. _________________ 1979 porsche 924 Na
Posted: Tue Jan 11, 2011 5:16 am Post subject: |
| the_mad_electrician wrote: | | I was thinking about using this method to make a box for ram air for my Webers. Have a box with a tube near the front with a filter kinda like a cold air intake. |
Be careful with whatever you design as you can cause more problems than you might solve. You'll want to ensure it is large enough to provide sufficient air flow for the all of the carb inlets at WOT and that the air flow is relatively equal.
I would look at using lost foam mold technique. Work the foam until shaped to what you're happy with, then smooth it out with tape and mold release wax and finally fiberglass and resin. Dissolve the foam and clean up any ugly bits.
http://www.rcgroups.com/forums/showthread.php?t=188980 _________________ Stefan
Posted: Wed Mar 09, 2011 5:44 am Post subject: |
I was talkin to a guy thats been makin molds with fiberr glass for a while..
He uses a product thats sprayed thru a 1.8 tipped gun. The stuff finishes like gel coat is used on the original piece that the mold is made from
its not heavy on the pocket book as well. _________________ 1979 porsche 924 Na
joecitizennn
Posted: Fri Mar 11, 2011 4:38 am Post subject: |
That reminds me, I have a mould for making 931 header panels in NC I need to get. _________________ 87 924s
88 924SE gone
447 hp cgt clone
87 924S gone
84 944 sold
83 944 sold
89 turbo S LSD, ABS etc
86 951 white rocket
85 944 sport everything.
84 944 sold.
87 944 sold |
