hose between waterpump and thermostat housing
Duncan
PostPosted: Sun Feb 13, 2011 11:42 pm    Post subject: hose between waterpump and thermostat housing Reply with quote
Is it possible to replace the small (chicane shaped)hose between waterpump and thermostat housing without taking either off?
And if not, which of the two should I take off? I would need to know for ordering a new gasket.
I tried the search but could not find it.
Duncan
1983 NA Alpineweiss since 2001
Peugeot 205 Generation
PostPosted: Mon Feb 14, 2011 11:34 am    Post subject: Reply with quote
If you're replacing it, then just carefully cut it after removing the clamps and draining the coolant level.
You can get a new one in there, but it will be a bit of a wrestle to do so along with the clamps. If the clamps can be opened and installed after the hose is in place, life will be much easier.
PostPosted: Mon Feb 14, 2011 2:48 pm    Post subject: Reply with quote
Take the thermostat housing side off !
jbwheele
PostPosted: Wed Feb 16, 2011 7:14 pm    Post subject: Hot water Reply with quote
Put it in real hot water then wearing gloves lube it up and wrestle it in........then take off the thermostat housing ....................
Joe
82 932 Stripped bare full rebuild
80 932 GT Lookalike Engine S2 swap
Duncan
PostPosted: Thu Feb 17, 2011 1:07 am    Post subject: Reply with quote
Do you have a glass ball at home?
Duncan
PostPosted: Mon Mar 07, 2011 1:34 am    Post subject: Reply with quote
To answer my own question:
Yes you can replace this hose without removing the thermostat .
datatrain
PostPosted: Mon Mar 07, 2011 8:11 am    Post subject: KY Reply with quote
I've found the best stuff for new hose installation is KY Jelly. It also has excellent uses for whatever is left in the tube.
'78 924 NA with Collector plate
Mint '92 318i BMW
Near mint '98 Buick LeSabre
VE7HFR
mikebola
PostPosted: Mon Mar 07, 2011 11:35 am    Post subject: Re: KY Reply with quote
+1 to that!
If I have to fight a hose to put it on, I tend to use some hairspray. When it's wet, it works like a lubricant, and when it dries, it gets tacky enough to keep it from sliding around (which is excellent if you're slipping a hose on a pipe that isn't flared) but not so much that it won't come off when you need to replace it. that's an old bike I use when I need to put grips on mountain bikes and BMX's.
proud owner of a 1979 924 Sebring Edition with a 931 trans that looks horrible but somehow runs...
