Newb intro, my possible project, and some questions....
SoCal924NA
PostPosted: Fri Jan 21, 2011 8:38 pm    Post subject: Newb intro, my possible project, and some questions.... Reply with quote
Well first I just wanna say "hi" from California.
This may be my first true project/rebuild. I'm normally found tinkering with Chevy's and Honda's (I know, big difference between makes lol) but this is my first European car.
I acquired this free 1980 924 N/A from a relative a few months ago. I was a bit disappointed to open the hood and find the little 4 cylinder sitting there, even more so it being the N/A model. The 5-speed and rear mounted transaxle were definitely on the bright side however. The car has 77,234 (124,296KM) miles on it. It was last driven in 2003 and hasn't moved since, supposedly a bad head gasket. I think the last owner just didn't have time for it. Unfortunately for me, it was left out in the California desert on private land all this time. So who knows what weather damage it has succumb to.
I started working on it a couple weeks ago, and after seeing all the damage I thought about just sending it off to a scrap yard. But I couldn't do it...
And now the pictures.
The exterior isn't as bad as it could be, a few dents here and there and the paint is peeling off.
Interior is actually still relatively well, just some damage to the front seats.
As for the engine...I don't know where to start. Everything is a mess and dirty as heck. Wires have been chewed and eaten away by rodents (most sensors - go figure), a lot of hoses and rubber parts are now old and brittle. Rust is everywhere coolant used to be. Belts were done and sticking to the pulley's and gear's. Pretty much all the gaskets are toast.
When I separated the head from the block, all this rust and white powder stuff fell out.
Most of the suspension and chassis components are okay. Some bad bushings here and there and the car needs a major brake overhaul.
Well, that's my quick little history. Now that you guys have seen the car, I have some questions. (I know little about the car aside from what I've read and remember in the tech section so I have no exact goals at this time)
1. Overall, do you think this car would be worth restoring in the end? Are they problematic cars?
2. This goes out to the other 924 owners here in Cali, are the cars reasonably easy to pass smog or are they just a bunch of problems? Is it even worth attempting performance upgrades in Cali?
3. Power increase would be a must, it'll probably be N/A after reading about the difficulties in converter these N/A over to forced induction. So for compression increase, what options am I looking at? One of the first things I noticed was the supposed use of a head gasket with part number 93110433703, but all I can find is 93110433706.
4. I've found pretty much all the OEM parts from EBS, Pelican Parts, and Auto Haus. But aftermarket wise, are there any good suppliers?
1980 924 N/A M/T
PostPosted: Fri Jan 21, 2011 11:46 pm    Post subject: Reply with quote
Wow, major reconstructive surgery is in order! However, some on the board have started with worse than that. Is the block stuck? Cam pitted? Things like that can set one back to not doing the project. I have lots of interior bits, and engine compartment bits from a '79 if you need it.
the_mad_electrician
PostPosted: Sat Jan 22, 2011 12:12 am    Post subject: Reply with quote
As far as compression, you'll need custom pistons. You should check out ideola's web site he has almost everything you need to get the most out of your n/a the only thing does carry is cams. http://garage.ideola.com
81 924 N/A
2004 Ranger "Edge"
2005 Mazda 6
Rattlinbone
PostPosted: Sat Jan 22, 2011 3:43 am    Post subject: Reply with quote
I started with worse than that, and now I have a cool daily driver.
Fred- 1979 924
PostPosted: Sat Jan 22, 2011 3:52 am    Post subject: Reply with quote
Looks like a heck of a project. Not the worst we've seen around here (CorsePerVita comes to mind)
Yup, Ideola has higher compression pistons and other neat parts. I highly recommend having the head ported and larger valves installed along with the more manly pistons.
Luckily, the 924 shares a lot of parts with the 944, including most of the interior and underpinnings. After 85.5, the 944 dash changed and isn't easily swapped, but it has been done before. The seats are the same between the 924/944 and 911 from that time period.
Suspension upgrades are as easy as finding a donor 944 or 924 turbo to steal the parts from.
Drivetrain upgrades a little more tricky since the 924 N/A has a smaller clutch spline and torque tube shaft.
If you're going to keep the CIS system, get yourself some books on the subject and the proper tools to test the system properly and it should work fine for you and your plans, provided the system doesn't need too much work done to it. Vacuum leaks, poor grounds and incorrect fuel system pressures will cause the majority of your problems.
Depending on your skill level with electronics, automotive electrical systems and engine tuning, you might look at MegaSquirt as a DIY EFI upgrade route. The trick with any external modification in the engine bay is dealing with the California smog police who focus on a visual inspection on top of an inspection of the tailpipe gasses.
Check out the sticky'd posts in the Performance Upgrades section to get some ideas on what can be done to improve the car while you've got it apart.
PostPosted: Sat Jan 22, 2011 3:58 am    Post subject: Reply with quote
SoCal924NA wrote:
...true project/rebuild.
Uh huh... to what level?
And how! A down-to-nuts-and-bolts strip and rebuild would be my guess. All that bodywork and a full respray, the body seals, the trim pieces, the interior, lights, glass, electrics, accessories... urrgh...
Unless you simply want to get it running and drive it around as a beater? And/or sell it for a few hundred bucks?
Really? What did you expect?
SoCal924NA wrote:
...after seeing all the damage I thought about just sending it off to a scrap yard.
No surprise there. No-one would blame you.
Kudos to you.
Wait 'til you drive it
But, mate, that thing is going to take some money from you.
So, the questions;
1a. You, like every noob I can recall that has graced this forum, fails to define "worth" in your terms to us (and very probably to yourself, as well). In monetary/investment-return terms? Emphatically no. For self-satisfaction and/or as a life lesson? Possibly. They are super fun cars to drive and pretty cheap and easy to keep. But unfortunately, given their age, there are now many, many cars as good and better in every way, and those cars cost much, much less than it'll cost you to bring that one back to life.
1b. Not when they're in as-new condition, no. Pretty much bulletproof. Electrics are tedious, I guess. But if you're doing a complete rebuild, just make it right.
2. Not 100% sure but I doubt it'll be a problem if it's stock, as-new condition.
3. Bwahahahahahaha! Buy a Turbo (or an S) There's some noob reading here.
4. Can't really help there. Have never bought aftermarket stuff from the U.S.
Good luck with it.
Oh, and welcome to The 'Board.
PostPosted: Sat Jan 22, 2011 4:32 am    Post subject: Reply with quote
Door speakers gotta go bro... You just need to strip the block
and have it honed plasti-guage the main and rod bearings and get some new rings and from what the pllasti-guage told you maybe some bearings.
Bearings dont cost alot so you should do it anyway. Good luck were
here to help.
9XX Girl!
PostPosted: Sat Jan 22, 2011 5:18 am    Post subject: Reply with quote
Joes924Racer wrote:
Door speakers gotta go...
I kinda like um
SoCal924NA
PostPosted: Sat Jan 22, 2011 8:13 am    Post subject: Reply with quote
Not sure about the block, I haven't tried moving it yet but I will very soon. The camshaft looks good and no damage that looks worrisome. I'm holding off on parts at the moment until I get it torn down, inspect everything and make a master list of everything I'll need, good to know though
Wow, thanks. Link is exactly what I was looking for.
So, the questions;
Good luck with it.
As far as having to tear everything down and build it back up. But I guess we all have our own definitions of a true project
When I first looked at the engine I was hoping for some of that good Porsche performance, even if it was 30 years old. After thinking though it's not so bad, I mean, it's still bigger than my Honda's engine
Worth would be more on the satisfaction level to me. They are very nice looking cars, just the performance seems a little....eh. I like my cars to not only look fast, but also feel fast. That's true, I'm sure I could find something already running with more bang for the buck, but already having 2 good daily drivers I want something to wrench on the side. Plus, and most importantly to me, I have never had a project car to tear down and rebuild it from the ground up so that itself is an experience I'm really looking forward to over the next year or more if it takes.
Thanks for the link, I've been reading and trying to gather as much information as I can about these cars in my down time so anything helps.
9XX Girl! wrote:
I kinda like um
They are some bulky speakers. But they sound good for the age
1980 924 N/A M/T
PostPosted: Sat Jan 22, 2011 9:26 am    Post subject: Reply with quote
SoCal924NA wrote:
Worth would be more on the satisfaction level to me. They are very nice looking cars... true, I'm sure I could find something already running with more bang for the buck, but... I want something to wrench on the side. Plus, and most importantly to me, I have never had a project car to tear down and rebuild it from the ground up so that itself is an experience I'm really looking forward to over the next year or more if it takes.
SoCal924NA wrote:
I guess we all have our own definitions of a true project...
Seems you and I agree, though. Reads as though you're in the right headspace for this. Sure do hope you have deep enough pockets
Good luck with it.
leadfoot
PostPosted: Sat Jan 22, 2011 1:11 pm    Post subject: Reply with quote
ditch the engine, if you know chevy's put a ls1 in there ...
parts and people who can work on these cars is getting thin...
better off salvaging what you can and selling parts and putting something modern in there. Gearbox / driveline will need to be swapped out for a 944 turbo setup if you want over 300 hp in the front
Stu
1981 ROW 924 Turbo -
carbon fiber GT mish mash
LS1 conversion in progress...
SoCal924NA
PostPosted: Sun Jan 23, 2011 1:14 pm    Post subject: Reply with quote
Believe me, I thought about such an engine swap. But recently California passed laws mandating that vehicles can only receive swaps from the same manufacturer that produced the vehicle and it must be from a newer car (81+) in my case, to be street legal. It's all just a big headache dealing with state refs and BAR.
1980 924 N/A M/T
PostPosted: Sun Jan 23, 2011 4:53 pm    Post subject: Reply with quote
Porsche 928 engine or an Audi motor.
PostPosted: Sun Jan 23, 2011 4:57 pm    Post subject: Reply with quote
If they sound good thats what counts ...gee thats a
stuffy law bout engine swaps.
PostPosted: Mon Jan 24, 2011 5:08 pm    Post subject: Reply with quote
Oregon's is technically similar, but they only care what comes from the tailpipe and whether there a codes set on the OBD equipped cars.
