Intermittent clutch issue
mgatlag
PostPosted: Sat Jan 15, 2011 5:57 am    Post subject: Intermittent clutch issue Reply with quote
Ok here's the deal. New clutch, TO bearing, pilot bearing, cable and had pedal mounts rewelded. Clutch works fine but the pedal is usually a little hard. Normally when car is cold. Then when it warms up a little, the pedal softens up a bit. Then every once in a while the pedal feels absolutely perfect for a few minutes. Then back to just a bit hard.
Both the cable ends are fine too and sits on the fork just fine. Can anyone think why this would happen?
Michael
'04 Ford Taurus - gone!!
(Slap Shot)
ManicCycle
PostPosted: Sat Jan 15, 2011 7:33 am    Post subject: Reply with quote
Did you grease the TO bearing and fork?
mgatlag
PostPosted: Sat Jan 15, 2011 1:25 pm    Post subject: Reply with quote
Yea I greased them pretty good when I installed them. Wonder if I can get some more up in there through the access hole on the bell housing?
Michael
(Slap Shot)
PostPosted: Sat Jan 15, 2011 3:01 pm    Post subject: Reply with quote
This may hurt if true... ya ready ok check the pedal assembly under the dash your looking for a cracked mounting bracket.
PostPosted: Sat Jan 15, 2011 5:45 pm    Post subject: Reply with quote
How is the cable routed in the cabin?
How are the bushings for the pedal?
I would check the cable and the cable jacket just to make sure that there isn't binding there. Then the bushings and cable routing in the lever on the bell housing and in the cabin, on the pedal assembly.
mgatlag
PostPosted: Sun Jan 16, 2011 1:01 am    Post subject: Reply with quote
Well I just had the mounting bracket rewelded a month ago because it came loose and popped a weld. And the cable is ran just like it is suppposed to be and is not kinked at all.
Michael
(Slap Shot)
PostPosted: Sun Jan 16, 2011 1:09 am    Post subject: Reply with quote
Make sure the pedal bushings are all nicely greased.
Slam
PostPosted: Wed Jan 19, 2011 2:06 am    Post subject: Reply with quote
Bushings for fork in bellhousing? Worn fork? What the fork?
I mean the bushes where the fork rides in the housing (but you got that... AGAIN I'm wasting valuable typing resources).
'84 944 - kid blew motor
'80 924 - gone
'78 924 - gone
'77 924 - rusting comfortably
mgatlag
PostPosted: Wed Jan 19, 2011 2:21 pm    Post subject: Reply with quote
Man I really hope it's not those bushings. I'm NOT taking the damn thing apart again!! Maybe some carefully aimed shots of lube can help it out. Gonna do the ones at the pedal too.
Michael
(Slap Shot)
leadfoot
PostPosted: Thu Jan 20, 2011 2:22 pm    Post subject: Reply with quote
two things that can affect the clutch quite considerably are the:
pedal return spring / which gives resistance to the depression of the clutch
and the cable sheath which can frey and jam over time causing alot of resistance.
Is it on the depression or release that is causing issues?
Stu
1981 ROW 924 Turbo -
carbon fiber GT mish mash
LS1 conversion in progress...
mgatlag
PostPosted: Fri Jan 21, 2011 3:27 pm    Post subject: Reply with quote
Actually it's on both. But every once in a while it's perfect, for a short time...
Michael
(Slap Shot)
PostPosted: Sat Jan 22, 2011 4:53 am    Post subject: Reply with quote
Going off of leadfoot's suggestion:
Take both ends of the clutch cable loose. Run the cable through the full range of motion, check for any frayed cable or rough spots. Move the pedal through its full range as well.
You may not notice bad pedal bushings with this method, but you might get lucky. At the very least, it might be worth crawling under the dash with a flashlight to watch the clutch pedal move to see if you can notice any play in the movement of the pedal that might cause occasional binding of the pedal.
If the pedal and cable check out, then you'll need to reassemble the cable, etc and open the inspection cover and watch the rest of the assembly move while you have someone operate the clutch pedal.
Spraying lube in that area could contaminate the clutch material and cause it to fail prematurely. So be very careful if you attempt this and use a small amount of lubricant and apply it carefully to the throwout bearing tube and the bushings for the lever arm. Use a thin paint brush perhaps with a white lithium grease.
