whitehawk66
Joined: 27 Nov 2010 Posts: 7 Location: Philadelphia PA
Posted: Wed Dec 22, 2010 3:24 am Post subject: Interior question |
Does anyone know, will the front and rear seats from a 1987 924s fit in a 1978 942? What I mean is, are they a direct bolt in replacement. I'd also like to fit the rear seat-belts as my car doesn't have any. How about the rear hatch struts?
Thanks in advance. |
poorsha924
Joined: 13 Nov 2007 Posts: 143 Location: Kansas City Mo
Posted: Wed Dec 22, 2010 6:46 am Post subject: rear seat replacement |
Hi there
The seats are interchangable. with a few modifcations the latch hooks are different ,for the upper part of the seat that folds down & you will have to drill holes in the body to attach the seat belt buckles a little tricky to work around the torque tube & drill holes to acomodate the retractors. I would locking nuts to secure the bolts to eliminate the worry of nuts backing off. If you have access to a late model 924 or 944 I would a good look of where hole placement should be & you should be able to locate the latch pins from a parts car hope this helps
Poorsha924 _________________ 79 924S snailshell
audi big bore t-body
16" turbo wheels |
