What a surprise!
Bockscar
PostPosted: Mon Dec 20, 2010 3:44 am    Post subject: What a surprise! Reply with quote
A few weeks ago, I bought a 1981 931 for the sum of $300. In the description of the craigslist ad, it said it had a "new engine". As the story goes, the original owner joined the army and got shipped away and he left the car with his sister. The story seemed a little too good to be true.. Until recently
Fast Forward to today:
Because of the utter disarray the engine was in (electicals unplugged, hoses just hanging every which way), we decided to lobotomize the engine to see if the engine was really new. Out exterior of the engine didn't appear to be, it was very dirty and there was all kinds of dirt and debris littered about the engine bay. As you can see from the picture above, the top of the head appears to be all new components, devoid of any wear or oil!
We stopped short of taking the head off because we couldn't figure out how to get the exhaust off without making an entire day of it. On a side note, is it possible to simply disconnect the turbo and pull the head off with the exhaust manifold attached?
Brian
'79 924 - Restoration In Progress
'81 924 Turbo w/EFI - Scrapped
Rich H
PostPosted: Mon Dec 20, 2010 3:56 am    Post subject: Reply with quote
'Simply disconnect the turbo'
If the hardest job on the car is simple then you'll have no problems!
Possible, but less time consuming in the long run to pull the motor, IMO.
Also, please cover that turbo outlet with a rag or plastic bag before some murphy-propelled item falls in there.
stevekat
PostPosted: Mon Dec 20, 2010 4:04 am    Post subject: Reply with quote
Not sure I see the wisdom of taking the head off if all the components look new. If they are, it is reasonable to assume a valve job has been performed. Once the head is off, would you then remove the pistons to examine the rings, etc.? Pressure test the head? The block?
I think the most reasonable course is to make sure all your marks are in the proper place, perhaps do a leak down.
Just a thought experiment.
"Never get out of the boat. Absolutely goddamn right. Unless you are goin' all the way."
Gone to new home: '81 924T, US version, CGT Intercooler, UTCIS-PT, Euro DITC, Greddy Trust MBC, Forged Fuchs Flat Dish 6's, Factory Recaro's.
PostPosted: Mon Dec 20, 2010 4:10 am    Post subject: Reply with quote
+1
Bockscar
PostPosted: Mon Dec 20, 2010 4:34 am    Post subject: Reply with quote
The main reason why I decided to take the head off is because it appears that some kind of rodent made its home right above the spark plug holes which don't have any spark plugs in them. Each spark plug hole is full of dirt and gunk and I'm afraid more crud has fallen into the combustion chambers.
And I didn't want to just assume the engine was brand new and assembled by a responsible person. For example, when we took the valve cover off, we discovered a large washer laying in there. Not sure if it would have caused any problems in the feature but, it was a good find. We're probably got to stop once we verify there is no gunk in the combustion chambers.
Brian
Bockscar
PostPosted: Mon Dec 20, 2010 8:50 am    Post subject: Reply with quote
Here's a good picture of the spark plug holes. It's bad. It's almost as if someone or something packed all of this muck in there. It looks like this on each of the 4 holes.
FYI, I normally have blue rags in each of the ports and other open holes. I took the rag out for this picture and promptly replaced it afterwards
Brian
captainspaulding
PostPosted: Mon Dec 20, 2010 10:04 am    Post subject: Reply with quote
Time to pull the motor inspect to see what you have. Then replace what ever seals may be leaking and give it a good detail.
Sounds like fun.
kyle
1994 VW Golf sport rally cross beast
2003 Dodge ram 2500 cummins family hauler
NASA tech insp Texas region
NASA comp license and certified nut case
PostPosted: Mon Dec 20, 2010 10:07 am    Post subject: Reply with quote
Wow yea thats pic says it all.
Dutch924-racer
PostPosted: Tue Dec 21, 2010 6:45 pm    Post subject: Reply with quote
looks like a mouse has been living there.
937 trackday car
Series 2 engine
951S turbo and intercooler
Fast road camshaft
leadfoot
PostPosted: Wed Dec 22, 2010 7:14 pm    Post subject: Reply with quote
insert "squeaky clean" and "runs quiet as a mouse" joke here...
Stu
1981 ROW 924 Turbo -
carbon fiber GT mish mash
LS1 conversion in progress...
Bockscar
PostPosted: Fri Dec 24, 2010 4:14 pm    Post subject: Reply with quote
Indeed!
Don't mind the blood in the first picture; I didn't realize how heavy the head was going to be and I crushed my finger while lifting it out.. Whoops!
Anyway, it appears that a mouse did indeed make its home on top of one of the pistons. Actually, there was debris on top of each of the pistons, some more than others. Talk about an interesting find.
Brian
PostPosted: Sat Dec 25, 2010 1:48 am    Post subject: Reply with quote
Your blood sacrifice will be rewarded, my son. Toofahs love blood!
Dutch924-racer
PostPosted: Sat Dec 25, 2010 7:19 pm    Post subject: Reply with quote
Nice engine !
I think with some dismanteling and cleaning you have got a nice find!
937 trackday car
Series 2 engine
Fast road camshaft
