Compression Ratio
Goto page Previous  1, 2
leadfoot
PostPosted: Sat Dec 11, 2010 11:39 am    Post subject: Reply with quote
helps if you remove the radiator if your going to do it that way so you have the clearance at the front of the motor, the torque tube is longer than you think. This way is the most likely to bend to torque tube if your not careful,
Stu
1981 ROW 924 Turbo -
carbon fiber GT mish mash
LS1 conversion in progress...
PostPosted: Sat Dec 11, 2010 11:39 pm    Post subject: Reply with quote
Also to drop the front swaybar, while I'm thinking about it - again, more room to move the engine forward. But yeah, that's the way to go.
garyj19
PostPosted: Mon Dec 13, 2010 10:40 am    Post subject: Reply with quote
thanks guys. i was really dreading doing all the tranny moving so thats good news. now all i need is spring to come...
early 77 924 na
endwrench
PostPosted: Fri Dec 17, 2010 3:52 pm    Post subject: Reply with quote
garyj19 wrote:
Has anyone ever tried to lighten rods at home with a die grinder (going easy, of course), and balancing them to eachother with a scale? Thats kind of the route i want to take... I know i can do it i just want some imput
As Vaughan said you can balance the rods and pistons with a postal scale but if you start to actually lighten the pieces then you will need to also rebalance the crank because it is counter balanced for the heavier pieces. This cannot be done on a postal scale.
Todd
Euro924S2
PostPosted: Sat Dec 18, 2010 10:00 pm    Post subject: Reply with quote
only down side to dropping the front cross member - you''ll need to get it re-aligned once it's all back in as you'll upset it all - you can try marking the position of the bolts for a budget best guess, but I'd recommend it at least get's checked.
I just spend £150 getting my 4 wheel alignment done only 1K miles ago so I've dropped the g'box and slid the t.tube back - the whole engine lifted straight out without removing the bell housing, alternator, starter motor etc etc I even left my thicker 944 turbo radiator in place - easy. The audi 5 speed gearbox is very simple to remove and the 4 speed even easier!!!
UK spec '83 N/A with 931 motor with Eaton MP62 'charger @ 15psi. EFI - 565cc inj. Standalone Adaptronic ECU. 951 FMIC. Ally rad. Twin throttle. Recirc valve. Custom manifolds and CAI. 232bhp
RC
PostPosted: Sun Dec 19, 2010 1:53 am    Post subject: Reply with quote
Todd
ROFLMAO
How true. And Todd knows what he is talking about too.
Also agree with Euro924S2`s post although dropping the Xmember is the easiest. You probably need a wheel align anyway unless it was recently done.
Allan @ DTA wrote:
garyj19
PostPosted: Sat Feb 19, 2011 3:41 am    Post subject: Reply with quote
im just going to drop the transaxle then, its not that hard.
and thanks for the tip on the rod lightening... ill just balance them if they arent close already.
early 77 924 na
Eturbo924
PostPosted: Wed Feb 23, 2011 11:15 pm    Post subject: Reply with quote
I have pulled two engines and did not drop the cross members.
I did pull the trans on one though.
Good luck!
Check out the bolt on articles and such.
1992 968
2003 C4S
E-mail me for parts you need!
Drive Fast!
Page 2 of 2
