Compression Ratio
garyj19
PostPosted: Thu Dec 09, 2010 4:24 am    Post subject: Compression Ratio Reply with quote
The motor in my 77 n/a is coming out next spring, and headed to the basement for a much needed rebuild. Originally, i wanted to keep the motor stock but lately i have wanted a little more go, so i want to take the upgrade route.
Just off the bat, i want to raise my compression ratio.
Does anyone know the ratio in my 77?
Can i simply fit in different pistons or is block and head resurfacing a good idea too?
and slightly o/t, but i will need motor mounts... are they NLA new?
early 77 924 na
PostPosted: Thu Dec 09, 2010 4:57 am    Post subject: Reply with quote
There's a whole shatload of info on a sticky right above this post! To not answer your question, not sure on compression though.
PostPosted: Thu Dec 09, 2010 5:53 am    Post subject: Reply with quote
Best thing, easiest route is take off some material on the block surface as you mentioned. Maybe search thru google for the correct amount,
its been thoroughly hashed over here. Cheers.
Rich H
PostPosted: Thu Dec 09, 2010 5:56 am    Post subject: Reply with quote
Euro spec your car? You'll need pistons and a few other bits.
Factory spec 125 bhp in easy reach...
garyj19
PostPosted: Thu Dec 09, 2010 12:38 pm    Post subject: Reply with quote
Yes, euro spec is what im looking to replicate i suppose.
And i looked in the sticky and although it had alot of great stuff , i didnt find too much about 924 n/a upgrades.
Anybody know of any horror stories about trying to push too much out of a stock bottom end?
early 77 924 na
the_mad_electrician
PostPosted: Thu Dec 09, 2010 12:53 pm    Post subject: Reply with quote
check with ideola, he has custom pistons and rods if you are willing to spend a some cash he can give you whatever compression you want and the rods (from what I have read) are the weak link in the bottom end of the 2.0 engine. As a bonus the custom pistons and rods are lighter
81 924 N/A
2004 Ranger "Edge"
2005 Mazda 6
924-76
PostPosted: Fri Dec 10, 2010 12:52 am    Post subject: Reply with quote
Euro pistons:http://www.924board.org/viewtopic.php?t=33870
1976 924 N/A ROW SOLD
1980 931S
1981 931 Part car RIP
PostPosted: Fri Dec 10, 2010 1:26 am    Post subject: Reply with quote
9.5:1 CR is pretty nice (what we're running in the racecars); since it's out, you should consider having it lightened and balanced. Shouldn't be a problem to take 100 grams or so off the big ends of the stock rods (though aftermarket are lovely)... I think the stock rods are just fine in the NA, it's more of an issue with built turbos.
Yours will either be 8:1 or 8.5:1, depending (more likely 8:1 I think)... 9.5:1 will really wake it up.
Consider having the flywheel lightened too, but don't overdo it; some have reported problems with clutch engagement.
PostPosted: Fri Dec 10, 2010 4:22 am    Post subject: Reply with quote
the_mad_electrician wrote:
the rods are the weak link in the bottom end
Not.
garyj19
PostPosted: Fri Dec 10, 2010 5:14 am    Post subject: Reply with quote
I was thinking thatd be a good idea too. Should it be lightened or should I buy an aftermarket ligher one? I'd call this a budget build, the Ideola site looks awesome but those rods are expensive
early 77 924 na
PostPosted: Fri Dec 10, 2010 5:40 am    Post subject: Reply with quote
If you have access to a machine shop who is willing to work with you, then I'd have the stock parts lightened and balanced and pickup a set of euro pistons to bump the compression ratio just a bit.
If you're thinking of going flat-out, then buy the lightweight rods and pistons and raise the compression ratio quite a bit more.
Then, you can drop a couple of grand on fixing the cylinder head with porting, stiffer valve springs, larger valves, lightweight followers and a more aggressive camshaft.
If you're really wanting to explore the limits of the 2.0L SOHC, then you can bore the block out to the max and have the crankshaft welded to increase the stroke to 2.2L or perhaps more. That's another couple of grand at least.
and so on....
garyj19
PostPosted: Sat Dec 11, 2010 1:06 am    Post subject: Reply with quote
Hahaha, budget build my friend! id love to do all that but the money is the issue... i do have access to a machine shop but id rather not.
Has anyone ever tried to lighten rods at home with a die grinder (going easy, of course), and balancing them to eachother with a scale? Thats kind of the route i want to take... I know i can do it i just want some imput
early 77 924 na
PostPosted: Sat Dec 11, 2010 4:26 am    Post subject: Reply with quote
Yes, that's a perfectly acceptable way to remove the weight - or with a bench grinder, actually. It's just a question of how much patience you have to grind - that's a lot of metal.
But yes, balancing the pistons and rods with a grinder and digital postal scale will be just fine.
garyj19
PostPosted: Sat Dec 11, 2010 5:10 am    Post subject: Reply with quote
Cool, thanks. i can have patience for anything that saves me money! Now i have to wait until spring to do it all...
Hey this may sound dumb but ive never had the bottom end out of the car- Do i need to pull the trans/torque tube back to pull the whole motor out?
early 77 924 na
PostPosted: Sat Dec 11, 2010 6:05 am    Post subject: Reply with quote
Nah, just drop the front crossmember out and the bolts off the bellhousing and it should come out just fine.
