Scorpio
Posted: Tue Nov 30, 2010 11:50 am Post subject: Clutch Upgrade NA - OEM Vs Audi 200 Vs Spec stage 2+ |
some pics of the three clutch systems- Spec stage 2+ then audi 200 then Stock clutch
The middle clutch is of the Audi 200 turbo clutch( we think) that came from Andrew NZ... seems to fit as per stock clutch--notice finger sizes-- Ill be using the spec stage 2+ but apparently the audi200 is a direct upgrade to NA (same fit but for a higher torque engine)
The throwout bearing supplied with the spec clutch setup is a good fit but the pilot bearing is too big or am i missing something??????
 _________________ 1979 NA
MS1..EFI..
GARRETT T25 TURBO
BILSTEIN SHOCKS
GT BASED CUSTOM BODYKIT
Brisbane , Australia
Think mean think fast
all youll see is
my Porsches Arse!!! |
flosho
Posted: Tue Nov 30, 2010 12:39 pm Post subject: |
Nice, looks very sexy! _________________ [This Space For Rent] |
endwrench
Posted: Tue Nov 30, 2010 3:49 pm Post subject: |
I'd be interested in the torque rating on the Audi 200 clutch and the Spec. Stock is 173 lbs. My "custom" set up is only 235 lbs and was a bit of a pain (but cheap).
http://www.924board.org/viewtopic.php?t=22052&highlight=poor+boys
Scorpio
Posted: Tue Nov 30, 2010 6:58 pm Post subject: |
dont ko\now about the audi unit but this is the email i got from David Norton at SPEC
Clutches are rated in torque, so for 250 ft lbs + with good clutch life I like st2+ or 3. The small 8.5 diameter is limiting, even with our high clamp load version. The st1 is OK just over 200 ft lbs, but I’d rather help you get into your budget than sell you something that may not live as long as you want. Has the car been on the dyno yet ?
AND
Yes, st2+ would be fine..stage 3 as well. The st3 is plenty streetable, but on the upper end of street aggressiveness, so the engagement will be quicker than a normal fiber based clutch. The st2+ is a hybrid and drives very nicely. So I would choose based on desired engagement feel from a stop..the 2+ will feel more like stock than the 3, but the st3 is still considered a street/track unit.
David Norton
P 800-828-4379 Ext: 110
F 205.491.8593
http://www.specclutch.com
so stage 1= 200ftlb plus and stage 2+ is 15% greater then stage 2 _________________ 1979 NA
MS1..EFI..
GARRETT T25 TURBO
BILSTEIN SHOCKS
all youll see is
Posted: Wed Dec 01, 2010 2:20 am Post subject: |
Just curious, is there a weight difference between the pressure plat? _________________ 1976 924 N/A ROW SOLD
1980 931S
1981 931 Part car RIP |
Andrew NZ
Posted: Wed Dec 01, 2010 10:21 am Post subject: |
Can't remember the exact specs, but I had the two tested, and from memory the Audi 200 one was about 30% stiffer than the 924 one. _________________ Andrew
1977 RX924 race car
12a bridgeport supercharged
www.race4-dcup.co.nz |
leadfoot
Posted: Thu Dec 02, 2010 6:52 pm Post subject: |
wouldn't they sell you a red one?
carbon fiber GT mish mash
Scorpio
Posted: Fri Dec 03, 2010 7:16 pm Post subject: |
| leadfoot wrote: | wouldn't they sell you a red one?
Stu |
I wish jellyfish.....ah well the clutch is hidden _________________ 1979 NA
MS1..EFI..
GARRETT T25 TURBO
BILSTEIN SHOCKS
all youll see is
CorsePerVita
Posted: Sun Dec 05, 2010 5:35 am Post subject: |
how much for the clutches? _________________ - 1977 Porsche 924 2.0 N/A (Trackday Project)
- 1980 Porsche 931 (Daily)
- 1987 Lamborghini Jalpa
- 1999 Ducati 900SS |
Euro924S2
Posted: Sat Dec 18, 2010 8:44 am Post subject: |
Interesting stuff. I posted on here a while back trying to see what kind of bhp/ torque the standard NA and turbo clutches could handle. Reason being I'm in the middle of a supercharger project on a turbo engine (aim 240bhp) but to go into a NA shell so whilst it's easier to keep the NA sized torque tube and cable clutch etc, there's no point if I'm going to shred it at WOT.
Have you been running your car with a standard clutch and if so what power did it handle?
I have a nearly new standard NA clutch which I'm going to trial just out of curiosity but I'm sure I'll be needing a spec 2.
Can you post up the costs for the spec items?? I'm in UK but good to know.
Cheers. John. _________________ UK spec '83 N/A with 931 motor with Eaton MP62 'charger @ 15psi. EFI - 565cc inj. Standalone Adaptronic ECU. 951 FMIC. Ally rad. Twin throttle. Recirc valve. Custom manifolds and CAI. 232bhp |
Posted: Sat Dec 18, 2010 9:11 am Post subject: |
| Euro924S2 wrote: | Interesting stuff. I posted on here a while back trying to see what kind of bhp/ torque the standard NA and turbo clutches could handle. Reason being I'm in the middle of a supercharger project on a turbo engine (aim 240bhp) but to go into a NA shell so whilst it's easier to keep the NA sized torque tube and cable clutch etc, there's no point if I'm going to shred it at WOT.
Cheers. John. |
For your application, you just need the NA bellhousing with an early 931 TT The clutch splines on the 931 are more common so swapping in a stronger clutch from another vehicle is a little easier. _________________ Stefan
