Andrew NZ
Posted: Tue Oct 06, 2009 7:16 pm Post subject: |
The car has finally finished a rally without breaking!! Seems the driveshaft is ok at last.
It was only a short event, but the car went well and the service crew had nothing to do all day It was a great feeling driving it home and in to the garage under it's own power.
The only thing I'd like to change in the future now is the gearing, as it's a bit tall at the moment for what I need. Still a fun car to drive though, and it gets a lot of attention. _________________ Andrew
1977 RX924 race car
12a bridgeport supercharged
www.race4-dcup.co.nz |
Andrew NZ
Posted: Sun Oct 25, 2009 2:34 pm Post subject: |
I did my bit for charity today. The Dunlop Targa NZ 2009 started today, and although I'm not a starter this time (budget's blown this year) I went out and took part in a grass motorkhana at the event start to raise money for "Cure Kids" - Targa's chosen charity.
We took people for rides for donations, and most people had a ball. The 924 is very interesting to drive on grass with slicks!! It was so much fun, and I'm even more keen try the car on a gravel rally now. _________________ Andrew
1977 RX924 race car
Andrew NZ
Posted: Thu Sep 02, 2010 1:26 pm Post subject: |
Wow, this year has gone fast!
I had a driving lesson with local rally legend Marty Roestenburg at the start of the year, and the car packed up about 10 laps into it! Lots of play in the diff, rear wheel bearings and the clutch started jamming again - all rather embarrasing in front of a pro!!
This prompted another rebuild, which has been held up due to a family illness, but I do have most of the parts to complete now. I worked on it for the first time over the weekend, and managed to get the engine out to check the clutch. The input spline was still touching the eccentric shaft, so will now be removed from the torque tube, and machined down to the right length. It's time to sort everything properly this time!
This weekend I'm hoping to get the gearbox, torque tube and rear suspension out so I can start on the full rebuild. The target is the Targa Bambina in March 2011.
Jobs to complete before then are:
Modify drive shaft
Rebuild gearbox and fit Audi LSD and 4.8:1 R&P
Fit Alloy rear arms and Koni coilovers
New discs and wheel bearings all round
Change front spring rate
Add extra bars to rollcage
Alter seat position and add adjustable pedal box (so my short wife can drive too )
Build new dash and demister
Rewire whole car
Cut rear guards and fit flares
Make front spoiler to fit in with flares
Refit standard glass all round (the lexan is a pain for Targas)
Remove aftermarket sunroof and fit roof vent
Paint it all bright pink
This thing is going to be bright, fast, comfortable and reliable by the time I finish this rebuild!
Will keep you all updated as I go. _________________ Andrew
1977 RX924 race car
Andrew NZ
Posted: Thu Sep 23, 2010 3:05 pm Post subject: |
Update:
Cut and welded the rear arches, and should completely finish the flares this weekend.
Dropped the driveshaft into the engineers today to get the spline shortened by 7mm and the recess in the spigot shaft metal sprayed and ground to extend the spigot shaft. This will to allow use of the mazda spigot bearing seal, and eliminate any binding between the spline and the eccentric shaft.
My mate Ray (www.rollcage.co.nz) has been around to look at the roll cage and made some good suggestions for making it even stronger. I'll get it to him once all the mechanical work is finished. _________________ Andrew
1977 RX924 race car
bnoon
Joined: 12 Oct 2009 Posts: 607 Location: West Des Moines, IA USA
Posted: Sat Sep 25, 2010 11:50 pm Post subject: |
Post pics or none of it happened!  _________________ '80 924 Turbo - SOLD!
Porscheless  |
Posted: Sun Sep 26, 2010 2:34 am Post subject: |
yea nice.. thanks 4 sharing.. cant waite to see. _________________ 1979 porsche 924 Na
Have u ever driven a turbo. |
Andrew NZ
Posted: Sun Sep 26, 2010 5:47 pm Post subject: |
| bnoon wrote: | Post pics or none of it happened!  |
I'll try to take some next weekend! _________________ Andrew
1977 RX924 race car
Andrew NZ
Posted: Sun Oct 10, 2010 8:43 am Post subject: Project RX924 begins! |
Poor quality pics off my phone I'm afraid, but here are a few to keep you going:
Please excuse the messy garage! _________________ Andrew
1977 RX924 race car
Posted: Sun Oct 10, 2010 11:13 am Post subject: |
You have it well in hand cant waite to see it on the ground.
I like the classic look of cookie - cutters. Cheers. _________________ 1979 porsche 924 Na
Andrew NZ
Posted: Sun Oct 17, 2010 6:06 pm Post subject: |
Got the newly machined driveshaft back in the torque tube today, so just need to sort out the gearbox now and I'll be ready to put all the driveline back in the car.  _________________ Andrew
1977 RX924 race car
924guy
Posted: Sun Oct 17, 2010 11:43 pm Post subject: |
awesomeness! _________________ Eric
78 924
82 931 SE "smokey"
99' VehiCross
Y2K Honda Insight
Performance by Pasha |
Andrew NZ
Posted: Sat Oct 30, 2010 9:53 am Post subject: |
I started pulling the gearbox apart last weekend, and also the Audi V8 LSD I had bought about a year ago. Imagine my surprize when I opened up the Audi diff housing to find a STANDARD diff! It was just very tight, so acted like an LSD when I turned it over by hand . Oh well, I'll remember to check things thoroughly next time I buy second hand parts off the internet.
The week picked up though when I managed to get a 944 front spoiler to modify for it for only $61 (they normally go for about $450 in NZ).
Works getting busy again now, so I'm probably not going to get much time to work on it over the next few weeks. _________________ Andrew
1977 RX924 race car
Andrew NZ
Posted: Wed Nov 10, 2010 8:15 am Post subject: |
I have the gearbox completely apart now, and have changed the bearings in the main case. Have sent the pinion shaft and main shaft to a transmission specialist to get the gears and bearings swapped over (at least that way I know it's been done properly!). Will hopefully be able to get the transmission back together in the next few weeks. _________________ Andrew
1977 RX924 race car
932kiwi
Joined: 06 Dec 2009 Posts: 44 Location: Wellington N.Z
Posted: Wed Nov 10, 2010 4:26 pm Post subject: |
| Is targa bambina still the goal? |
Andrew NZ
Posted: Wed Nov 10, 2010 9:04 pm Post subject: |
| 932kiwi wrote: | | Is targa bambina still the goal? |
Sure is  _________________ Andrew
1977 RX924 race car
