Lowering rear suspension without removing rear beam
nrwilliams
PostPosted: Sat May 29, 2010 12:03 am    Post subject: Lowering rear suspension without removing rear beam Reply with quote
Hello,
Quick question. If I were to cut holes in the rear cills of my car to allow the torsion bar cover to come through will this allow enough room for the ride height to be adjusted without removing the rear beam?
I saw a couple of 924 race cars last week which had holes in this location and I can only think it is for the above purpose.
Anyone think this sounds correct?
Thanks
Neil
PostPosted: Sat May 29, 2010 12:40 am    Post subject: Reply with quote
Hard to imagine the PITA level of doing that as less than dropping the carrier, if you are only doing it one time. I believe race guys might do it to experiment with different bars.
But it answer to your question, yes, that is why the holes are there.
PostPosted: Sat May 29, 2010 2:03 am    Post subject: Reply with quote
There was an article from back in the day that talked about doing this.
They machined off the end of the torsion bar carrier, drilled and tapped the end of the torsion bars and then marked and cut a hole through the sill of the car using a hole saw I believe. The hole in the body was capped with a simple plug made from the removed bodywork and painted black and held in place with a bolt threaded into the end of the torsion bar.
To adjust ride height, pre-load, change torsion bars, etc the crew would simply need to raise the back of the car up, remove the plug, thread in the end of a slide hammer and gently use the hammer to remove the torsion bar, adjust the control arm position with a jack (or replace the bars) and put it all back together and back on the ground.
PostPosted: Sat May 29, 2010 2:34 am    Post subject: Reply with quote
fiat22turbo wrote:
They machined off the end of the torsion bar carrier.
Not the carrier. Called "strut" in PET (?), called spring plate by me.
PostPosted: Sat May 29, 2010 2:43 am    Post subject: Reply with quote
Okay, just going from memory there, but it seemed that he magazine wonks called it a carrier.
Bottom line? Its the tube thingy that sticks out the side of the rear suspension and holds the end of the torsion bar.
PostPosted: Sat May 29, 2010 7:51 am    Post subject: Reply with quote
EMC Motorsport here in the UK who specialise in 924/944/98 race cars cut a hole on my sill to allow easy re indexing of the the torsion bar after fitting my GAZ Gold coilovers. This allows quicker ride height adjustment for various tracks subject to the surface quality. Thankfully being a Turbo I have sill covers to hide the hole behind.
PostPosted: Sat May 29, 2010 5:27 pm    Post subject: Reply with quote
For adjusting it feels pretty unnecessary, If you do some thinking ride heigth should be almost spot on when you change the bars. Then there is the adjustability in the spring plate which allows for plenty of adjustment easily done by turning an eccentric.
RC
PostPosted: Sun May 30, 2010 4:08 pm    Post subject: Reply with quote
Heaps easier to R&R or index TBs with the hole that Porsche put in the earlier cars.
Captain_Kirk
PostPosted: Thu Oct 07, 2010 3:52 am    Post subject: Reply with quote
Bringing up an old post here. I have searched and read every post here about reindexing my torsions bars and I am still left with some questions.
I want to lower the rear end just to level the car. I have a '77 NA (May of '76) and it has the holes in the rocker panels to pull out the spring plate just like in the pic above ^^^^ so I don't need to drop everything out of the car.
My car does not have the eccentric bolt so don't tell me to use that first. All I have are three bolts holding the spring plate to the hub, two of the bolts are holding the sway bar inplace. So where is the tension on the suspension? When I unbolt the spring plate from the hub will it want to rotate? Then do I slide it off the torsion bar, rotate it, then bolt it back up? Or do I unbolt the spring plate from the body first? Am I going to need spring compressors on the plate to hub connection to get it bolted back up?
I understand all the splines and degrees and all that so don't just send me to another link cause I've read them all and all seem to pertain to the next year and newer cars that have the eccentric bolt and more hardware holding them together.
I'm just trying to figure out where the actual tension is in the suspension so things don't come flying apart when undone.
Thanks in advance.
Captain
1977 924na BlackSeaRD.com Torque Tube SuperBearings, Xenon air dam, 200# Weltmeister springs, Bursch header, 944 exhaust, Audi throttle body
PostPosted: Thu Oct 07, 2010 5:09 am    Post subject: Reply with quote
You'll need to raise the car, remove the wheels, and support the trailing arms, maybe after raising them a tad, before unbolting the spring plate. If you want this process to take less than forever, I recommend a cheap angle finder from the hardware store.
As you probably figured out, because you don't have the adjustable spring plate to make fine adjustments to ride height if you are a bit off on one side, you will have to get it tits-on.
Try and rotate one tooth at a time (meaning, one inner tooth and one outer tooth at the same time). This is the finest adjustment possible.
Did you find the spreadsheet on the Spec944 website?
PostPosted: Thu Oct 07, 2010 5:26 am    Post subject: Reply with quote
BTW, if you want to swap your rear arms out with the adjustable steel arms from my 79 and/or a set of stiffer 944 torsion bars. They're yours if you want them.
I'll give them to you for the cost of shipping. I'm down in Portland, so it shouldn't be too bad.
PostPosted: Thu Oct 07, 2010 5:58 am    Post subject: Reply with quote
No-brainer.
Captain_Kirk
PostPosted: Thu Oct 07, 2010 7:56 am    Post subject: Reply with quote
Whooosh. That's the sound of it going over my head. My wifes a math teacher (trig, calculus, algebra, geometry) finally I found something she can help me on the car with.
fiat22turbo: are the arms adjustable as in they have the eccentric bolt on them? Is that the arms your speaking of? Anything else needed to adapt them to a 4-lug drum set up? Shoot me a quote on shipping to 99212 business address.
I was hoping there would be an easy solution to just dropping the rear a bit. I've got some 15" wheels and 195/55-15 tires and there is alot of space showing in the wheel well.
Can I just rotate the spring plate or do I need to pull the torsion bar and rotate it? Can't the inner end of the torsion bar stay in place and just turn the spring plate or am I missing something.
Thanks.
PostPosted: Thu Oct 07, 2010 8:14 am    Post subject: Reply with quote
No Cap'n! They can't stand the str-r-r-r-rain!
Aye, Cap'n, you'r-r-r-re missing the whole damn thing! One outer tooth'll dr-r-r-op ya more than two inches! Besides which pulling off the spr-r-r-ing plate without disengaging the inner-r-r-r splines is nigh on impossible!
PostPosted: Thu Oct 07, 2010 8:21 am    Post subject: Reply with quote
The arms are from a slightly later 4-lug car and still have the drums attached.
They have the eccentric bolts to fine tune the ride height.
You need the spring plates (meaning you get to reindex the torsion bars) and the trailing arms I believe. It should all bolt up like stock.
I know someone else in Portland that is selling the appropriate bits to convert your car to the 5-lug setup. You would need new wheels though.
The 944 torsion bars should be a nice upgrade for a relatively stock 924. You'll probably want to upgrade the front springs at some point though to help keep it better balanced along with swaybars, etc.
