flosho
Posted: Thu Sep 16, 2010 4:17 am Post subject: (Ultimate) Hypothetical Dash Reconstruction Solutions... |
If you were going to DIY your own dash, what method have you, or would you do. What products would you use?
For example:
Strip off the cracked dash material, lay down some expanding poly foam, sand, and layer bed liner, then sand smooth and reapply?
Or maybe instead of roll on bedliner, try to stretch some sort of fabric across the dash?
My dash is out, and I'm going to attempt to recover it in some way shape or form. I know there are a lot of attempts (and successful ones at that!) but I'd like to gather all the solutions into one thread. The more detail the better. Also pictures are a benefit! _________________ [This Space For Rent] |
Posted: Thu Sep 16, 2010 7:14 am Post subject: |
Uploaded with ImageShack.us
3M Di-Noc for that carbon fibre look. _________________ Porsche 924 1984 (UK import) NA
Posted: Thu Sep 16, 2010 7:41 am Post subject: |
As an alternative to the spray can expanding foam - could go with Gorilla glue, or an equivalent polyurethane glue from another maker.
Dribble it into the cracks and watch it foam up as it dries (if you have nothing better to do). _________________ "..it's made in Germany. You know the Germans always make good stuff."
Rattlinbone
Posted: Fri Sep 17, 2010 4:27 am Post subject: |
I've seen several examples of dashes that have been sanded, filled with expanding poly foam, sanded again and then covered with leather or vinyl. I really like that look.
I'm not too crazy about the carbon fiber look on 924 dashes. I mean, it looks cool, but I don't think it looks appropriate on a car as old as a '79 924. Personally, I'd rather go with something that looks period correct.
YMMV _________________ Fred- 1979 924
Posted: Fri Sep 17, 2010 6:04 am Post subject: |
Ihy on the leather looks quite swank donut. Cheers. _________________ 1979 porsche 924 Na
Have u ever driven a turbo. |
Rattlinbone
Posted: Fri Sep 17, 2010 8:52 am Post subject: |
ihy? _________________ Fred- 1979 924 |
flosho
Posted: Fri Sep 17, 2010 9:26 am Post subject: |
| Rattlinbone wrote: | I've seen several examples of dashes that have been sanded, filled with expanding poly foam, sanded again and then covered with leather or vinyl. I really like that look.
So do u tear the old vinyl off the dash or start sanding the original dash surface? _________________ [This Space For Rent] |
Posted: Fri Sep 17, 2010 10:27 pm Post subject: |
Start sanding the original dash surface. _________________ "..it's made in Germany. You know the Germans always make good stuff."
Posted: Sat Sep 18, 2010 3:30 am Post subject: |
Yea by diving in an jus starting sanding start rough then switch to a finer grit and youll get a smooth surface, you can even feather the plastic skin into the foam. _________________ 1979 porsche 924 Na
Min
Posted: Sun Sep 19, 2010 5:53 am Post subject: Re: (Ultimate) Hypothetical Dash Reconstruction Solutions... |
| flosho wrote: | | If you were going to DIY your own dash, what method have you, or would you do. |
A complete new one formed to the original shape out of 1/16th aluminum.
924guy
Posted: Sun Oct 03, 2010 11:01 am Post subject: |
Ive been pondering the same thing... no answers yet, just pondering the question...
Though using a large truck rubber inner tube has occurred to me.... _________________ Eric
78 924
82 931 SE "smokey"
99' VehiCross
Y2K Honda Insight
Performance by Pasha |
